I just fixed mine but I did 3 different things but my inks were empty...now that I replace the inks it works but not sure which one of the 3 fixed it so here they are
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
For printer model: Canon BJ F900, F890, F700, F500, S900, S820, S750 and S52:
1. Turn off the printer.
2. Press and hold the RESUME button, then press and hold the POWER button.
3.
Release the RESUME button, then press and release the RESUME button two
more times in succession. (you?re still holding the POWER button during
this). The printer mechanics will move momentarily.
4. You are now in Service mode.
5.
Pressing the RESUME key will select a function; for example, pressing
RESUME 4 times will select the clear waste ink counter function. The
lamp will alternate color with each key press.
1 times - Factory/Service test printout, including ink sensor check
2 times - EEPROM info printout
3 times - EEPROM initialization
4 times - Clear the waste-ink counter
5 times - Printer model setting. (more selections beyond this- leave this alone)
After
selecting mode, press the POWER button to commit the change, and return
to the top of the function selection menu. Pressing the POWER button
again turns off the printer for a restart.
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
our message reads 'check printer' meaning our waste ink tank is full but no one can tell me where it is located. Canon's answer is to take the printer in to a place not at all close and spend a small fortune. Meanwhile back at the farm my multipass won't work at all until the waste ink tank situation is resolved! Help !!
Hi motofox.Thanks for the help,but do you have any ideas on how to fix my waste ink problem for my F-80 mutilpass?
Thanks for replying motofox.Any ideas on how to help me with my waste ink problem for my F-80 mutipass?
