Car Audio & Video Logo
april Posted on Mar 31, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2008 Nissan Altima will not let me insert a cd. I push the button to enter a CD and it asks me what slot of the CD changer i want to use, i chosse one and then it promts me to enter a CD. As soon as I begin to put the CD in the CD player starts to force it out and my reader say “Ejecting Disc...” so I take the CD out fully and then the reader says “Insert a Disc?” Even if i try again from this point it still doesn’t work. WHY??? I bought it used and have never been able to use the CD changer.
Al Schrader
Level 3:
Master:
  • Master 438 Answers
  • Posted on Mar 31, 2019
Al Schrader
Master
Level 3:
Master:
Answers
438
Questions
0
Helped
144718
Points
1228
Suggest replace player.
5 Related Answers
Anonymous
  • 752 Answers
  • Posted on Sep 11, 2007
SOURCE: cd changer
The laser is dirty (happens alot in a car, especially the trunk) or damaged. a repair shop is your best bet.
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on Apr 30, 2009
SOURCE: Car stereo wont accept disk (motor doesnt pull it in)
you are correct it is not "seeing" the disk with it's infared sensor to repair this sensor you must disassemble the radio
Anonymous
  • 255 Answers
  • Posted on Jun 28, 2009
SOURCE: Dell Studio 1537 DVD not working
1. clean your cd, then put
2. clean your cd/dvd head
3. scratch cd/dvd shows this type of message
Anonymous
  • 55 Answers
  • Posted on Jun 30, 2009
SOURCE: CD player is not working.
I would first try removing the fuse to the radio/cd player, see if that resets the system and get the cd out.
Hope this helps some.
Matt
joerocket999
joe wright
  • 28 Answers
  • Posted on Jul 27, 2009
SOURCE: Jeep Cd Changer "Disk Error" message
Well if you didn't already know all jeep chrysler dodge factory cd players don't work very well. I have sprayed high pressure air into mine and it has help but may not solve the problem permanently. I would suggest buying a new cd player. sorry
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
CD stuck in my Honda Odyssey CD changer
Turn van off. Open & close drivers door, wait for everything to power down. Turn van back on and push button to close CD/Nav opening. It will close. Having an issue with CD player also.
2008 Altima with factory nav/cd changer. 2 CDs were stuck in the changer, which I was able to remove. However, the disc indicator lights remain Green for discs 1 and 2 even though there are no discs in the...
unless you can repair the cd unit its gonna be a replacement.
or you could transfer all your cds to mp3 and play them through your fm radio........until you sell the car
7helpful
3answers
Cd jammed in player
MY DAUGHTER PUT A CD IN THE CD PAYER AND NOW MY CD PLAYER DOES NOT WORK.I HAVE A 2005 NISSAN ALTIMA.THE KIND OF RADIO IS A BOSE 6 CD CHANGER.I PRESS THE CD BUTTON AND IT SAYS PUSH EJECT.I PUSH EJECT AND IT SOUND LIKE IT'S TRYING TO EJECT BUT NOTHING COMES OUT.CAN YOU HLP ME
98 Isuzu Rodeo 6 CD changer error code 3 - CDs will not come out. Thanks!
After reading about a similar solution from another person, I gently inserted and removed a flat, piece of plastic partially in the CD slot, and out popped my 1st CD. I pushed the button for the next CD, inserted the plastic briefly, and the next CD came out. Got them all out the same way. It was almost too easy :)
2answers
Changer won't acknowledge discs
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
36helpful
8answers
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
