Sewing Machines Logo
Gail Birkeland Posted on Mar 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Feed dogs won't come up - Sewing Machines
Danielle Evans
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Mar 30, 2019
Danielle Evans
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
238
Points
What machine are you using?
MrFixitSTTL
Level 3:
Master:
  • Master 340 Answers
MrFixitSTTL
Master
Level 3:
Master:
Answers
340
Questions
0
Helped
166762
Points
1713
Look for a lever that puts them down for free stitching/quilting. Often near bobbin may look like a rocker switch.
3 Related Answers
bargainbox
Hassy
  • 1388 Answers
  • Posted on Nov 02, 2011
SOURCE: husqvarna optima 620 feed dog won't stay raised
If you have switched to "UP" position and turned handwheel one full revolution with no result it may be that
1. There is lint under the needleplate preventing it from rising fully....clean it out !!
2. There is damage to the linkage and will need to go in for visual appraisal by technician....ask for a quote on repair before they do anything.
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Apr 02, 2012
SOURCE: Feed dog loose and won't lock in properly in the
then the machine needs to be checked at a sewing machine repair shop
to be fix
Tally Girl
Tally Girl
  • 1134 Answers
  • Posted on Nov 03, 2012
SOURCE: elna sewing machine 7000 geting bobin won't go through the feed dog
sorry, not sure I understand your problem. can you elaborate?
Have you got the correct Elna bobbin for your machine? check your manual, it should have an image of the bobbin, the 7000 was one of the last Swiss made Elnas and although a computerised machine, it still tool the Elna metal bobbin with 7 holes on one side only. If you are using another bobbin in the shuttle, it may not function correctly.
if you can add some more info I will try to help you further.
1helpful
2answers
Hi Brenda.
if you go to this google link it might help you out.
Feed dogs won come up Google Search
1helpful
Feed dogs lowered can't raise material not feeding thru
Is your machine mechanical? If so, sounds like the feed dogs are stuck in the lowered position. Needs good cleaning and oiling.
Perhaps this will help:
The feed dog knob won turn don think anything is broken haven used the...
I have a singer 543 the feed dogs won't move.
I suggest getting out your manual and looking up lower and raising the feed dogs. When the feed dogs are lowered they don't move. You could have lowered them without realising it.
Fabric won't move threw machine, feed dogs are working.
Try adjusting the pressure on the presser foot, or make sure your feed dog are in up position and moving forward
Feed dog won't come back up
Try jiggling the hand wheel as you push/slide the feed dog button.
Material won't feed through on kenmore 17600 sewing machine
Take out the material, take off the foot and needle. Stick your finger on the feed dogs and hand turn the hand wheel like sewing. Does the feed dog come slightly above the surface of the needle plate? If it does.... tighten the presser foot tension.
If it doesn't locate the switch that drops the feed dog. Make sure it's in up position.
If neither of those solutions work. Remove the needle plate and see if the feed dog or mechanism that runs it is broken
Good luck
9helpful
2answers
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
4helpful
2answers
I put the feed dogs down and now they won't go back up, what do I do now?
1helpful
Have Viking 990 and feed dogs not working. Local repair man kept for over a month and then said it was the circuit board and that Viking no longer making circuit board for 990-- or, that machine can't be...
Is it that the feed dogs won't go up and down, or that you can't adjust the stitch length? If the feed dogs won't go up and down after you have released the feed dog button and cycled the handwheel one revolution, than there is a mechanical adjustment needed. I the stitch length can't be ajdusted, that It's either a circuit board of a step motor problem. The repair shop should be able to tell you that they swaped the feed motor with the zig zag motor to test this issue.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
