Let me sent you 2 sites that may help.
Free User Manuals and Owners Guides ManualsOnline com
ManualsLib Makes it easy to find manuals online
SOURCE: User manual needed
sorry this is all I could find with out a model #
http://www.orion-tv.net.au/Remotes.pdf
http://www.orion-tv.net.au/manual/20VROT.pdf
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: tuning in my orion tv
Do you just mean to select channels, or do you need to have it search for active channels (programming mode)? If just select channels, then most remotes have channel up & down buttons, in addition to the number pad. To select by numbers, use 2 digits: 04, 06, 08, 10, 22 and so forth.
If the set needs to be placed in the setup or autoprogram mode to search for active channels, then the menu functions must be used.
You may be able to find an online manual on Orion's website. Use your TV model number.
SOURCE: universal tv remote control codes for a hikona tv/dvd combo
you have to set the code for TV alone, then code for DVD
SOURCE: Orion tv/vcr combo to work with Philips universal remote?
phillips universal remote with orion 1326 tv.
ned code
SOURCE: TV CODES
tengo un control remoto universal GH RC84912 nesecito los codigos l para un televisor philips me lo pueden enviar a mi correo [email protected] de ante mano gracias
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
