Question about Boating
Brand new unit and the depth and temp features not working and not getting a reading of the bottom. Worked the 1st time then not the 2nd time,
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 85 Answers
Check for a loose connection or corrosion at the transducer and the unit. Less likely, but bent or broken pin on the connector at the back of the unit. It always works until it doesn't, so that information is of no use.
Posted on Mar 30, 2019
SOURCE:
SOURCE: Depth Sounder does not display depth
I will see if I can get mine off the hull for testing. Still have found no procedure. Thinking about just replacing the sounder with another unit.
Posted on Aug 03, 2008
SOURCE: 2nd time using this brand new machine and it won't brew.
try unplugging the unit for 1 1/2 hours to reset the electronics...I just called them and that was their advice...we shall see..worth a try
Posted on Aug 16, 2008
  • 5 Answers
SOURCE: 2003 Ford explorer transfer case and shift motor problem
need more information on this one.
Posted on Feb 17, 2010
canontech
  • 1219 Answers
SOURCE: I rifil canon Fax -JX
by refilling the ink crg. you probably destroy head electronics. Buy new one ORIGINAL, and try then.If you must refill ink be carefull, rather buy new reffiled ink, where the chip is resetted.
Hope that helps!
Posted on Aug 10, 2010
  • 3 Answers
SOURCE: My 570 quit showing the depth and continues to
I had the same problem. It was the transducer.
Posted on Aug 30, 2010
2003 chevy trailblazer cooling temp running 230
Smart man using a scanner for the actual temp. Assuming you're not losing coolant....2 things I'd look at here, 1st is you may have air in the system, make sure to purge all the air. 2nd is your fan clutch, I've replaced a few fan clutches in my own Trailblazer. Have had them bad right out of the box brand new. Have had bad brand new fan clutches on 2 of my last Trailblazers. You should hear it engaging especially in stop and go traffic.
Aug 02, 2016 | 2003 Chevrolet TrailBlazer
Fedders Air conditioner
Try a hard reset first.Disconnect the machine for about 30 minutes and reconnect after that to see if the issue is resolved.
Jun 07, 2008 | Fedders A6P09S2A Air Conditioner
Sonar not Working
Transducer not parallel to bottom - kicked up. Manually set depth to see if the auto depth is the problem.
Aug 12, 2017 | Lowrance Elite-4x DSI Sonar with...
The unit worked fine for 3-4 months.Now,it just gives a reading of 0 ft. with the water temperature. Once in a while while i'm drifting it will give me a depth for a few seconds and go back to a 0...
It sounds like your transducer has gone bad. You may be able to find a replacement on Craigslist or eBay, since this is an older model. Transducers are pretty sensitive to bumps and drops because of the crystal inside.
Aug 23, 2011 | Humminbird Piranhamax 170
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
Amana AC model MBR2000, installed mid May 2009. When outside temp gets above a certain level the AC does not cool. fan keeps running and it keeps trying but not work. When outside air gets cooler then...
Hi it sounds to me like what actvates the 2nd stage of the compressor is not turning the compressor on when the ambeint temiture reaches the point that it calls for the 2nd stage to start it may be an out door thermostat or a ambient senser and I would request a new Tec to come out and ckeck
Aug 24, 2009 | Heating & Cooling
Raymarine ds500x brand new works good but will give false bottom readings occasionally corrects itself fairly quickly 30 seconds to two minutes wondering why it does this and how to correct it
If the transducer is not correctly mounted this may happen due to air, etc. If the unit never gives a depth reading that looks like dashes
( - - ) then there is likely nothing wrong with it aside from the transducer placement.
Aug 06, 2009 | Raymarine Ds500x Color Fishfinder: Ds500x...
New fridge not cooling
Check the warranty, call the company.
Jul 16, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Aug 09, 2007 | Cuisinart DTC-975 Coffee Maker
Boating Logo
37 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
