CODE: 9E1, PH1, 9E2, Plo, AE (Power/not switching on)
Action:
Please switch off the appliance at the mains, and then wait 30 seconds before switching it back on again.
If this does not solve the problem, are you using an extension lead or multiple plug?
Plug another item, such as a mobile phone charger, into the power point that your washing machine is connected to, to check if the problem is the power point or machine.
We recommend connecting your machine directly to a power point rather than using an extension lead.
If your machine still has no power, you may need to replace the fuse in your washing machine plug.
SOURCE: Error Code
Here's some magic help on the dryers: I have a duet sport- Whirlpool hides the complete service manual inside the cover at the bottom front of the machine- remove the bottom 2 screws, drop the cover & you have all test & service instructions--- (:
SOURCE: My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
SOURCE: AF Error Code
If thats not it, then you nay have a faulty sensor.
AF
Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Testimonial: "Thanks so much!"
SOURCE: Dryer won't start
If it is brand new then it is under warrantee, and should be fixed for free or replaced by the seller. If you try to fix it yourself, sometimes that could void the warrantee.
SOURCE: kenmore elite dryer 110 8772 He5 lights up, will
MANUAL DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
-Close the door.
-Select any one key (except STOP) and follow the steps below, using the same key (remember the key):
Press/hold 4 sec's.
Release for 4 sec's.
Press/hold 4 sec's.
Press/hold 4 sec's.
Press/hold 4 sec's., release
NOTES:
-Press the same key to advance to the next failure code.
-At the end of the procedure the program will loop back to the beginning. This is a continuous loop.
-To cancel out of the Manual Test Mode press STOP.
Exit Condition Control Action To be Checked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
