How do I reset a Yahama htr 5140 receiver to factory settings?
    New Friend:
  • 50 Answers
    New Friend:
  • 30 Answers
Unplug reciever for 5 minutes also as soon as you unplug receiver hold power button for 30 seconds. This should empty out power therefore erasing memory / settings
Posted on Mar 30, 2019
  • 1 more comment
  • Kenny Johnson
    Kenny Johnson Mar 31, 2019
    Thank you Jerry. it seems that the power down thing allowed me to get my headphones working in some modes and reset audio settings in effects to factory delays and such.
  • jerry fitz
    jerry fitz Mar 31, 2019
    Ok I'm not sure about any other factory resets. Unless in the menu.
  • jerry fitz
    Set the unit to Standby Mode using the Power button. (Upper left corner.)
    While holding down Straight button, hit the Power button. ...
    Use the Program Selector buttons to navigate to INIT CANCEL and press the Straight button to select ALL.
    When the proper selection is made, turn off the unit using the Power button.
SOURCE:
  • 3 Answers
SOURCE: Yahama HTR-5560
I own this unit also and have found that it is very sensitive to speaker wire shorts. Please recheck all speaker connections to make sure you have no "stray wires" touching someplace to make a short.
Posted on Jan 23, 2009
DickCanFixIt
  • 948 Answers
SOURCE: We are hoping to purchase an owner's manual for
Click the DOWNLOADS tab from this page.
Posted on Feb 21, 2009
xscrewdriver
  • 246 Answers
SOURCE: factory settings
I only found this on the manual
if the power is cut for more
than one week, the parameter value you edited will
return to the factory setting."
Posted on May 13, 2009
SOURCE: I have a HTR-5140 stereo receiver 6 years old used
there should be schematics or a Manuel in pdf form online that should tell you where the fuses are.
Posted on Feb 01, 2010
  • 6 Answers
SOURCE: my front speaker just stopped working. I've tried
check to see if there is a fuse on the back of the speaker.
Posted on Aug 20, 2010
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
What's your problem?how to reset yamaha htr 3065 to factory settings
I had the same trouble to reset this machine into factory setting and finally, I found out. Let's do this way.
- Leave your remote away as you won't need it
- Turn off the the unit to STANDBY mode
- Press and hold STRAIGHT button on the unit and press Power button while you are holding it. This will turn on the machine.
- Once the machine turns on, press PROGRAM to select the items on LCD display until it shows INIT **** CANCEL
- Press STRAIGHT button until it turns to INIT **** ALL
- Press Power to turn off the machine.
- Leave it for 2 sec. then turn on the machine again.
Now your unit turns to factory default setting.
Feb 25, 2013 | Yamaha HTR-3065
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Factory settings
May 13, 2009 | Yamaha HTR-5540 Receiver
How do reset receiver back to factory setting
Initializing PRESET
Use this feature to reset all the parameters of this unit to
the initial factory settings.
Choices: CANCEL, RESET
•Select “ANCEL”not to reset any parameters of this
unit.
•Select “ESET”to reset the parameters of this unit.
Apr 16, 2009 | Yamaha HTR-6130 Receiver
Yahama HTR-5560
Oct 27, 2008 | Yamaha HTR-5560 Receiver
Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
May 01, 2007 | Yamaha HTR-5990 Receiver
Yahama HTR-5730
Here's the manual; http://www.yamaha.ca/av/PDFs/Manuals/2004_receivers/HTR5730E.asp See if you find a solution in there - if not please ask again and we will see what we can do :)
Apr 16, 2007 | Yamaha HTR-5730 Receiver
41 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
