Televison & Video Logo
bruno binelli Posted on Mar 29, 2019
Sanyo FW55C46F comes on and off repeatedly. no effect using set buttons or remote ?
How to program my sanyogxdb remote to w ok rk my pioneer elite vsx 33 rece v er
To program your Sanyo GXDB remote to work with your Pioneer Elite VSX 33 receiver, you can try the following steps:
  1. Turn on the Pioneer Elite VSX 33 receiver manually using the power button located on the receiver itself.
  2. Hold down the "Code Search" button on your Sanyo GXDB remote until the LED light on the remote stays lit or blinks.
  3. Press the "TV" or "DVD" button on the remote, depending on which device mode you want to program the receiver to.
  4. Enter the corresponding code for Pioneer receivers. You can find a list of Pioneer remote control codes in the instruction manual that came with your Sanyo GXDB remote or by searching online. Enter the code using the number buttons on the remote.
  5. Point the remote at the Pioneer receiver and press the "Power" button. If the receiver turns off, it means the remote has been successfully programmed. If not, repeat the process using a different code from the list until you find the one that works.
  6. Once the remote successfully turns off the receiver, press the "Code Search" button again to save the code. The LED light on the remote should turn off or stop blinking.
  7. Test the remote by pressing other buttons, such as volume up/down or channel up/down, to ensure it is functioning properly with your Pioneer Elite VSX 33 receiver.
If you're still having trouble programming the remote, consult the instruction manual that came with the Sanyo GXDB remote or contact Sanyo customer support for further assistance.
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
3helpful
I need the codes to a sanyo tv and i have a brightstar br100z remote
The Sanyo codes appear to be 620, 801, 931 . Turn on the TV, press and hold Set-up until the light comes on and enter the three digit code. Check if the TV responds (volume, channel). If not try the next code.
To search all codes: turn on the TV, press and hold the Set-up button. Then press Channel + slowly but repeatedly until the channel changes. Press Enter (if you overshoot, press Channel - to before pressing enter.) To record the code, turn on the TV, press and hold Set-up, then press Set-up again and type 0-9 individually until the indicator light blinks. That is digit 1, repeat the search from 0-9 for the other two digits.
If your TV was released ~6 months before the remote was programmed or is newer than the remote, then the code you need may not be in the remote's programming. In that case, you need a newer remote, one of the remotes that is programmable (USB to a computer), or a remote specific to your TV (try remotes.com and search on the TV model - leave off the brand name).
I hope this helps.
I need a code to use a universal remote on a Sanyo TV, model # DS13330
Codes depend on the remote brand. However, if your TV was built 6 months before the remote was programmed or was manufactured after the remote was produced, then it may not have that code.
RCA remote codes for Sanyo include: 017,021,039,056,057,058 . You can also try the search for code function: turn on the TV, press and hold the code search button. When the indicator light comes on, press and release the TV button. Then hit ON/OFF once per second until the TV goes off. (This can take 100 tries.) Press Enter. If the TV responds to other commands, it is set. Otherwise repeat the scan.
Philips remote codes for Sanyo: 002 412 506 619 902 (for one of the units) Use http://www.urc.philips.com/ to find your specific remote and its code list.
I hope this helps.
Need to program the rm-v302 remote to a sanyo dvd/vcr player
Most of the combo units are hit and miss on using entry level remotes, Learning remotes or high end remotes are you two best bets.
You can try these Sony Remote Sanyo VCR codes:046, 044, 035, 033, 038
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the SET button.
  3. While holding the SET button, press and release the POWER button
  4. Release the SET button.
  5. Press the appropriate component button for the component being set up.
  6. Using the number pad, enter the component's manufacturer code. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  7. Press the ENT button.
  8. Point the remote control at the component.
  9. Press the POWER button to verify operation.
Programming a sanyo tv with rcu403a remote and
Hello Jeffro
Programming a device using the Code Lists:
1- Sanyo 017,021,039,056,057,058 (codes)
2- Press and "HOLD" CODE SEARCH.
3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH.
6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists
Hope this helps you out.
Cheers Little Dish Fitter
Code for tv
Sanyo is 0154
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
1helpful
3answers
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
