SOURCE: electric start not working 8hp.mtd. snowblower
Hi, check the starter if it's engaging too the flywheel. there is plastic molded gear on top of your starter some times gets broken.
If this doesn’t work for you please write back. Thanks,
SOURCE: I have a vm80 8hp tecumseh engine 150092D day
If you want a 'drop-in' replacement, you will HAVE to source a carb that was fitted as original equipment. Following the demise of Tecumseh's engine division, supply is limited to 'old stock', but there is fair spares aqvailability at present. A newer 'primer start' carb will fit, but you will have to remove all the choke operating mechanism. Don't fit a carb from a larger or smaller engine - the mixture will be wrong, and the engine will never run properly.
SOURCE: gas flows freely out the carborator pn 632351 on a tecumseh 8hp
needle and seat valve stuck open remove float bowl and find the cause
SOURCE: No problem, just wanted to know if you can still
yes,depending on the part you can still get parts.some parts they obselete but you can still find them.go to your nearest outdoor power equipment dealer they usally will have the part you need or they can tell you where to find it.
