Testimonial: "I know how to get my tape out, I am talking about the red tab on the side of the cassette, It won't close...and the cassette gets kicked out of the VCR"
Check the cassette door sensor: Make sure that the cassette door sensor is clean and free of debris. If the sensor is dirty or blocked, it may not be able to properly detect the presence of a cassette in the VCR.
Try unplugging the VCR: Unplug the VCR from the power source, wait for a few minutes, then plug it back in. This may reset the cassette detection mechanism and allow you to open the cassette door.
Try using the manual release: Some VCRs have a manual release mechanism that allows you to manually open the cassette door. Check the user manual or the VCR itself for instructions on how to use the manual release.
If none of the above steps work, it's likely that there is a problem with the cassette detection mechanism or the cassette door sensor. It's recommended to contact a professional technician for repair.
It's worth noting that the problem might be caused by a malfunctioning mechanism or parts, that may need to be replaced and it's best to be addressed by a professional technician.
There are two reasons normally that the cassette door won't open when you slide the Eject button on the JVC GR-SXM320. One: the camera uses a powered eject feature. If the battery is low and the AC adapter isn't plugged in and powering the camera, this doesn't work. Two: if the LCD monitor screen is not open to more than a 60 degree angle, then there is an interlock that keeps the cassette door closed. This avoids the door hitting the screen. It's best to have the monitor at a 90 degree angle to the camera body when you open the cassette. Press Stop if there is a chance that the camera is recording to the current cassette.
Note: since the camera is older, check that the AC adapter is getting warm when it's plugged in and connected to the camera. This checks if the adapter is working. Check if your battery pack is good. If you have the BN-V856U battery pack, you need the AA-V80U charger to charge the battery. The charger that came with the camera will not work.
Third party battery packs and chargers are still available for the GR-SXM320. Use the manual to look up the part number and Google for the battery or use the camera model number to find available parts. For example, a replacement BN-V11U battery is available at Amazon and here: https://www.bestbatt.com/JVC-BN-V11U-BN-V12U-BN-V14U-BNV-V18U-Battery-p/bbbnv11u.htm .
That lever is there for a reason. The adapter needs a battery in it to run the motor to lace up the small tape before it goes into the VCR. If it goes in without the tape being laced it won't play and might cause damage.
The infra red light in the middle of the mechanical deck, that powers the left and right photo sensors is not ok.It looks like a small lamp( you cant see it when it works-Infra red mind it).The video cassette has a large round opening in the bottom towords the front, and accomodates this lamp.please check it out.
I'm having a similar problem. The camera is a Sony
DCR-TRV280.
When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down.
In other words the mechanism works fine without the tape but with the tape it doesn't.
I hope the explanation is clear enough.
Thanks
The cassette adapter uses 1 AA battery. When you place your VHSC tape into the adapter and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink wrap has been removed from the battery
