The only things that I can see that would stop everything from working is if you defrost time is stick in defrost, or if your thermostat failed. Look at the picture below.
The defrost timer is part number 6. If you drop your control panel in the refrigerator, you'll be able to advance the timer with a screw driver to see if it turns on.
If that doesn't work, jumper the 2 wires at the thermostat, which is part 9, and see if that turns it on.
Of course, do what I listed with the power off, then plug it back in after you do what I told you to check
SOURCE: The appliance interior lights works but it's not cooling or freezing
The compresser could fail yes, but you could also have an open circuit. If the contacts in the thermostat got corroded, or the starter relay, it may simply not be told to turn on. It may be time for a technician to measure continuity in the circuit.
SOURCE: Whirlpool Refrigerator - Model# ED22LF
Tom, I would start with the overload and relay that is on the compressor, If it is white it's a good possibility that it has failed. The fact that both sides are not cooling leaves me to believe the compressor is not operating. Take the overload and relay off. If they are both contained in a white cover shake it. If it rattles, I believe that is your problem. Let me know what you find...Catriver.
SOURCE: Side by side unit not working on both sides
Check your modeel number again as I can not locate the model you gave.
Look at following areas for the model number
SOURCE: have a Whirlpool refrigerator that has stopped
replace the electronics on the compressor --if you would like more tech diagnosis let me know
SOURCE: LG Refrigerator side by side suddenly not working at all other than interior lights.
If you're lucky, it's just the capacitor on the motor. Have it checked, but be prepared to need a new compressor.
The defrost assembly
consists of three main parts. The defrost thermostat, the defrost heater and
defrost board. Any of the one is not functioning. When thermostat sense the
maximum cooling, it triggers the defrost heater to start heating and this
defrosts the ice collected on the coils and the system works. Both thermostat
and heater are controlled by defrost board. First the thermostat and
defrost heater to be checked, if both check ok by meter and visually, then its
defrost board causing the problem. You can get required parts from
online sites like: --- www.repairclinic.com or from searspartsdirect
online site.------------
Before that you can
try manual defrost reset procedure. The manual defrost
reset procedure is as follows : ----First unplug the unit from main power outlet. Then empty whole unit
completely. Then keep both the doors open. Wait for 24 hours. All the ice collected
on the coils and in the freezer section will get melted. Clean the
water from the sections. Then Connect the power cord of the unit to main power
outlet after 24 hours/.Then set the temperature to normal in both fridge and
freezer section. It will take near to 4 hours to get run in its proper cooling
cycle. Then check, if the problem returns again.Then go for replacing the parts.-------------------This should
help.Thanks.Helpmech.
