SOURCE: amana ALW480DAW washer
Remove the front panel by loosening the two screws that hold it in place. Unhook the spring that puts tension on the tension pulley. Remove old/worn belt and replace with new belt. Very important that you use the correct size belt or the motor may be damaged and remember to hook the spring back for the tension pulley. The new belt has to go around the inside of the tension pulley.
SOURCE: washer will not drain water or go into rinse and spin cycle
First thin I would try is to check your thermal fuse for continuity.
Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter
diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd
and tends to collect lint. Run a coat hanger up the hose and see if you
can fish something out also check that belt.
SOURCE: Kenmore washer not draining water
check for defective lid switch or switch just out of adjustment.
SOURCE: won't drain or spin
Sounds like the lid switch which is only about 30.00 to fix if you do it yourself. It's a little difficult but it's much better than replacing or having someone come in and do it
