The charger is fine (tested with another macbook pro). The battery is new and charges well in another macbook pro. I would like to know what could be wrong?
SOURCE: Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
SOURCE: old john deere gator and battery new charger still will not move
Could be several things. Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger. You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
SOURCE: battery doesn't charge
i had the same problem so i took the battery out and pluged the moped in and it ran so i knew the battery had a prob then i took the battery out of the canvas case and it had expanded to the point were it almost leaked (exploded battery in other words)
