Measuring Tools & Sensors Logo
Michael Spearman Posted on Mar 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dw100as is showing a calibration weight of 500g, how do I change it back to 100g
marcelakis
Level 2:
New Friend:
  • Expert 35 Answers
  • Posted on Mar 28, 2019
marcelakis
Expert
Level 2:
New Friend:
Answers
35
Questions
0
Helped
22146
Points
113
Simple, remove the batteries, leave a time without, then put back in place, will return to factory settings alone
  • Michael Spearman
    Michael Spearman Mar 29, 2019
    Left batteries out for almost 24 hours and I still have the same problem.
1 Related Answer
mhkamran
Hasan Khan Amran
  • 184 Answers
  • Posted on Aug 18, 2009
SOURCE: PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
2answers
How many cups is 100g of sugar
1/2 cup
Here is how volume/weight conversions work. A gram is a unit of weight. A cup is a unit of volume. Volume is the amount of space an ingredient occupies and weight is the mass or "heaviness" of an ingredient.
500 grams of mini marshmallows = 10 cups
500 grams of flour = 4 cups
500 grams of sugar = 2.5 cups
As you can see, the weight for these ingredients are the same, yet the volumes are different. This is because each ingredient has a different density.
Here is another example:
A cup of feathers and a cup of lead pellets both occupy 8 fluid ounces of volume. The feathers will weigh a lot less than 8 ounces on a scale and the lead will weigh a lot more than 8 ounces on a scale.
Asking how many cups equal 100 grams would be the same as asking how many hours are in a 100 inches. Volume and weight are two completely different measurement systems... just as time and length are two different measurement systems. The only difference is that volume and weight can be linked through density.... mathematically speaking. Density = Mass divided by Volume. Density can change for the same ingredient. For example, a cup of sifted flour will weigh a lot less than a cup of unsifted flour. A pint of water will vary in weight depending on the temperature of the water.
There are websites that do volume/weight conversions based on density. Two great websites are:
http://www.onlineconversion.com and
http://www.gourmetsleuth.com or, you can look in a cookbook that has a volume/weight equivalency chart.
Apr 15, 2015 • Home
I have a supreme weigh sw02 digital pocket scale i need to calibrate and need help
500ml 0f water is exactly 500g, measure that volume and put it in freezer bag and use as calibration weight, or if you have friend with scales - borrow from him scale weights.
if you use water - accuracy of the scale will not be absolute, it may vary few g either way.
another way - go to shop and buy 500g block of butter - put it on the scale in the shop - remove or add as you need till you have exact 500g, shop scales are accurate on that weight within 2g
do not forget to vote if you find this answer useful...
How do calibrate my scale. it is a asking for 500.0 grams of weight to do this. can i use coins? if so what
two cups of water are about 500g, 500ml of water is 500g, just measure 500ml of water, put it in no leaking plastic bag and use as a solution to your scales calibration problem, as i am assuming you will not use it to weighting 500g of d0pe or m eth, error of 2 or 3 grams will be of no importance!
regarding fixya - stupidity of censorship is astounding! d0pe and m eth in correct spelling are regarded as profanities...
Jan 02, 2015 • Home
My digital gram scale does not work. the screen has some kind of word. Please help
Try recalibrating it by turning it on while holding the "tare" or "mode" button. It should show a raw data from the sensor then. Press the tare button again and it should calibrate the empty weight. Then it will show a specific weight you should put on, usually 100g. It should automatically finish calibration now. Hope this helps. The words before calibration on my scale was OUt2
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
[email protected]
4helpful
2answers
How to calibrate 1000xr us-magnum digital scale
magnum 1000xr pocket scales turns on calibrates goes to different modes but wont show the weight when object placed on the scale,a lock appears in top left of window, is scales broke or do i have to make lock symble dissappear?
10helpful
4answers
Mini digital scale displays out2
I just had this problem on set Salter scales (says 3309 on label on back so assume that's model no) which came up OUT2 solidly after hadn't been used for a while.
Looking on WWW this means on other scales they need to be recalibrated. There are only 2 buttons on ths model ON/Zero and 2nd is mode for grams, oz etc. Discovered by trial and error have to hold down the on button and repeatedly click the measure button as it powers up, screen says err2 press on button again and says 5000g, put 5000g weight on scales, press on button again display says CAL press on button and it at first came up with EEEE and failed but next attempt it said PASS and it all worked again. I used 2 x 1.5kg bags flour and 2 x 1Kg bags sugar to make 5kg with bit tipped out of one to make exact and checked on another set scales. So trick appears to be finding how to get your scales in to calibrate mode and what the weight it expects is.
Top Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
