Take the buttons off of your unit and remove the board cover by taking out the 2 screws on each side holding it in. You will See on the right hand side of the board 4 post specifically , 2 for your indoor thermistor and 2 for your outdoor. unplug your inddor from the board ( make sure power is off) and there should be a plate you can remove on the front of the unit on the right hand side of your evaporator coil , remove this and disconnect your thermistor from the coil (should snap right off ) pick up a new thermistor and just slide it right back in.
