Question about Boating
My duramax 55 lb thrust trolling motor won't work. I changed the board and now the battery charge indicator just flashes 5 times then nothing happens
    Top Expert:
  • 1,116 Answers
Posted on Mar 29, 2019
SOURCE:
SOURCE: mINN kOTA 70 LB THRUST FOOT CONTROLLED TROLLING MOTOR
VONNY MY MOTOR DOES THE SAME THING AND I FOUND THAT THE DUST OF THE MAGNETS IN THE HEAD WAS CAUSING THE MOTOR TO STICK I CLEANED INSIDE WITH ELECTRICAL CLEANER AND IT STARTED TO WORK FINE BUT YOU MAY HAVE SOMETHING ELSE GOING ON AND ALSO MAY SURE YOU ARE NOT COVERED UNDER WARRANTY IF YOU JUST GOT THE BOAT
Posted on Jan 21, 2008
  • 8 Answers
SOURCE: motor won't run
Look at the red indicator arrow when you hit the foot pedal. If it lights up, the motor should run. If not, inspect the splices under the top cover on the shaft. They will stop the motor if corroded or burnt.
Posted on Nov 28, 2008
  • 323 Answers
SOURCE: Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
Posted on May 23, 2009
  • 5 Answers
SOURCE: i have a 37 lb thrust motor guide stealth 5forward
trolling motor parts.com
Posted on Apr 30, 2010
unitedinteri
SOURCE: how should a 12 volt deep cycle battery last when trolling on #1 with a 30 lb thrust
It depends on the Amp/Hour rating of the battery and the amount of current your motor draws on setting 1.
Posted on Jun 11, 2012
Good battery , good battery in remote 70 lb thrust trolling motor - no go. ?
Hey Rob,, ??? ..Did you have the batteries CCA checked?? Cold Cranking Amps..?.. this is the only check to determine if your batteries are actually "good"...Next, take a volt meter and check the voltage at the trolling motor connection..if you have voltage at the plug, its time to move up to the head of the trolling motor...Since I do not know what brand if trolling motor we are working on.. these guys will take care of you from here...
home
Jul 09, 2017 | Boating
How should a 12 volt deep cycle battery last when trolling on #1 with a 30 lb thrust
Apr 17, 2012 | Minn Kota Endura 30 Freshwater Transom...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Boating Logo
44 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
