You can download manuals for most laundry machines from this site. http://laundry.manualsonline.com/search.html
How big is your cabin because even though it is a condenser dryer you may still need ventilation due to the small size of the room.
How to Replace A
White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance
Video Repair help see our video section
White knight tumble dryer not heating this video show you
how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux,
Ignis, Neutral, Tricity Bendix, Whirlpool, Here is the elementin this video For all you tumble dryer spare parts click here
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Hi, - The first thing to do is UNPLUG THE DRYER! Then remove the heater cover situated on the back panel. It is the curvey shaped panel.
Remove all the screws and the panel may be slightly stuck - just prise it off.
Next - there are 2 small screws holding the heater and thermostats assy onto the back panel. - Remove these to free the assy from the back panel. Be careful not to touch the elements as they break easily.
The problem is probably the Thermostats.
The one on the left is the Overheat Thermostat - You will notice a small hole in the centre of the thermostat. Take a Pin and push it firmly into the hole and you may hear the Stat "click". That has re-set the stat.
Re-assemble the Dryer being careful with the elements.
Now - Why has it tripped? If it has overheated it is because of one or all of the following.
1. The Condenser unit is getting blocked - Remove and clean under running water like a hosepipe or tap.
2. The door filter is not being cleaned
3. Sometimes opening the door to check if the clothes are dry and then not allowing the dryer to cool down can cause the problem. Always allow it to go through the cool down process.
Hope this helps. The Heater and the Thermostats are available as Spares - Terry
