SOURCE: Sharp LC37G4U Liquid Crystal Flat Screen
If this also happens on a DVD or video recorder, you could have a power supply issue or maybe a problem with the back light circuit. The best advice would be to take the TV back where you purchased it, if it is new. If it is not a new set, take the TV set to a repair shop for an estimate. Good Luck
SOURCE: code to program polaroid vcr/dvd combo and a new sharp lcd tv
Try 1061 or 1020 hope it works.
SOURCE: Sharp LC46SB54U Liquid Crystal T.V
This screens are all but impossible to replace.You only have a couple of options. 1. Buy a replacement screen for the television manufacturer 2.Find the same make and model of television with the screen intact and purchase it. This can be done by watching websites like e-bay and craigs list for these items. You can go to the websites and use their search engines with the brand name and model number tofind the televisions or the parts that are for sale. If you can find the part number of the lcd screen. You can try to locate the lcd screen maker and buy the part from them. By far the lowest cost alternative is to find a television with other problems, that is not repairable and buy it and use the parts. You can also look for it in local newspaper ads and yard sales. I hope this information helps you with your problem.
SOURCE: Is the Sharp LC-22DV17UT (combination liquid
That TV/combo unit does have a VGA port, so it should be detected as a standard monitor from the G5 at 1366x768 resolution. I'd definitely try to upgrade the G5 to Leopard if it isn't detecting - Leopard has far better monitor support than Panther or Tiger did...
SOURCE: I need the code for my "sony" universal remote control
SI esta utilizando un remoto marca phillip solo daja presionado code la luz se encendera luego pincha tv y con el botton de cambiar canal le das up varias veces hasta que el tv cambie de canal y luego le das enter y listo
