SOURCE: My Canon Camera 1100D after take 1 shot an err30 appear
Err30 indicates a problem with the camera shutter. Turn off the camera. Then remove the battery, take out the memory card, and then remove the lens. Clean the lens contacts and replace the lens (make sure that it is a Canon lens). Then replace the memory card and the battery. Then turn the camera back on.
If the error recurs, the camera needs service. Contact Canon.
I hope the problem is resolved by the above steps.
SOURCE: how do i reset my sunsui 19 inch hdmi tv to factory seting because I'm getting a cloudy signal
To reset it to its factory settings, you have to enter its service mode option. Do not change any values there if there is not necessity. Select the factory mode option only. To get more details about how to enter the service mode,http://electronicshelponline.blogspot.com/ check this link. It has details about how to enter and exit service mode. After entering the service mode, and have done the settings, it is a must get out from it, by using the exit option. All procedures are given there in detail. Pull up older posts there, by the sites' left side bar.
SOURCE: factory setings
RECORD on PAPER CURRENT Printer SETTINGS AS will be lost.
IP address used FAX Settings and what ever you use.
http://www.lib.ucdavis.edu/ul/services/mfd-3300-printing.pdf
Found this procedure on internet
http://www.ehow.com/how_7376251_reset-canon-ip-3330-printer.html
