Question about Hotpoint Dryers
I have a Hotpoint Gas Dryer DLL1550RALWN The motor will not start?
    Top Expert:
  • Hotpoint Master
  • 63,068 Answers
THEN GET IT REPLACED
Posted on Mar 28, 2019
2 Suggested Answers
SOURCE:
  • 221 Answers
SOURCE: hotpoint gas dryer will not tumble
Try checking the belt that wrap's around the drum, sound's like it might be broken.
Posted on Apr 06, 2009
My condo has a Hotpoint dryer. It is about 3 years old and last fall it no longer dried. I took the dryer hose off from the wall and the dryer works fine, heats the condo. The dryer vent goes into the...
Hi.
With most Hotpoint/GE dryers the blower motor is not spin by a belt. The problem is unlikely the blower motor. The problem is lint in the air ducts and in the blower housing. The lint results in overheating and the high limit switch cuts off the power to the heater (burner or element depending on the model).
As a result the dryer does not heat up.
Access the heating group and remove lint from the air ducts. Also clean the lint filter.
Hotpoint appliances are built by GE. Below service manuals for different GE-manufactured dryers:
Technical Service Guide
Service manual
ELECTRIC & GAS DRYER SERVICE MANUAL(Kenmore)
Jun 14, 2011 | Hotpoint Dryers
Hotpoint model no. dlb1550ralad. Dryer starts but stops immediately when start switch is released.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 10, 2010 | Hotpoint Dryers
We have had this hotpoint for a year and a month. First when pushing the start button it just hummed and did not start. After several attempts it started but is hotter than it has ever been when running....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Yes, the motor is going bad....
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 09, 2010 | Hotpoint Dryers
My hotpoint condenser tumble dryer keeps triping the mains in my house when i try to switch it on
you could have a defective start switch on the dryer motor, bad motor bearing making motor drag and draw excessive current or a heater element shorted to the dryer case
Oct 18, 2009 | Hotpoint NLL113EYWO Electric Dryer
Older Ge Hotpoint Dryer will tumble but not light the gas to heat
You state it is an older dryer, so I'd suggest replacement. The water may have damaged numerous components, including the motor, which would be costly to replace.
Aug 28, 2009 | Hotpoint NWSR483GBWW Gas Dryer
Hotpoint gas dryer will not tumble
Apr 06, 2009 | Hotpoint NVL333GY Gas Dryer
HOTPOINT DRYER VTD00G REPLACED BELT BUT WONT SPIN
Most likely to be a faulty start capacitor.
This a round plastic cylinder adjacent to the motor.
This gives the motor a kick start.
Dec 02, 2008 | Amana ALG443RAW Gas Dryer
Hotpoint dryer
Completely disassemble your vent from the dryer to where it exits the building. Clean out all lint. Disconnect the dryer from the electrical service and check for lint build up inside the machine. This lint build up usually makes the motor shut down on it thermal overload. Check the motor also to see if the air vents on it are blocked with lint. If no lint is present, the motor or the start relay need to be replaced.
Oct 24, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Wiring diagrame for hotpoint gas dryer
E-Mail me and I will send you a copy of my Schematic. It's 2 pics, but they are pretty clear and should help you. I came to the site wher I saw your post looking for a pic of an exploded view of our dryer. Trying to open it to fix the glide bushing. Started makin metal to metal noises lately, so I am assuming it's like a nylon glider for the drum?
SyxPakk@Yahoo.Com
Mike.
Feb 19, 2008 | Hotpoint NVL333GY Gas Dryer
Dryer not working
there are some switches that have to be closed before the hit start WILL FUNCTION. Most obvious is the door switch. a thermal overload in the motor circuit may have opened preventing power getting to the motor. check the overload in the blower housing. just jump it out with a piece of wire [temporarily] if it starts, replace the overload.
Sep 12, 2007 | Dryers
Dryers Logo
37 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
