Zenith 27inch B28A11Z keeps powering itself off
Hi Pswglaw,
From the way you describe the problem, it seems you have a high voltage
leak. To check this, make the room dark and look into the back of the
TV while turning it on. If you see something like lighting jumping
around you have this high voltage problem. The TV will eventually
destroy itself under this condition. I would suggest not using it until
you get it repaired. The repair cost will be much lower if the TV is
still working when you take it in. The high voltage leak will destroy
more parts and cause the TV to stop working. Then it will blow a fuse.
MyTvGuy
Can the fans be replaced? Don't have the $$$ replace TV. Still a great TV, until couple days ago.
