Question about Casio Watches
I have a Casio Sport 2894, is there any way to mute the button sound? I’ve looked in the manual and can’t seem to find anything.
  • Casio Master
  • 26,819 Answers
Press B to switch to the Timekeeping Mode. [SET Hold] will appear and the time offset value will flash. Press B nine times to display the button operation tone setting screen. Selecting [MUTE] causes a mute indicator to light and the buttonoperation tone will not sound.
Button Operation Tone Setting - Other Settings - STB ... - Support - Casio
https://support.casio.com/global/en/wat/ble/stb1000/manual/function/ose_but.html
Videos as well
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&ei=C-abXJn_KsW-jwS4qqSwCQ&q=casio+watch+silence+buttons
Posted on Mar 27, 2019
4 Suggested Answers
SOURCE:
  • 12 Answers
SOURCE: casio protrek 2894
The battery does NOT need replaced.
The word "Open" on this watch means that the sensor inside the back of the watch has detected that that the back is open. I ended up having to repair this problem myself after a local watch repair guy told me he didn't want to mess with it. You'll have to get a micro-philips screwdriver and remove a few screws and pop the end caps off to get to your problem.
After you have removed the screws and end caps inside the back there's a small spring that pushes against a copper disk glued to the back of the watch. The problem is that Casio has used a crappy glue to hold this disk in place and it needs to be removed and reglued to the back in it's proper place with super glue. It's a pain in the **** but I have repaired mine by doing this. BTW...I have found a video or another help for this fix on line so I won't go too much into it. Do a Google search and you'll find the step by step process listed elsewhere.
Posted on Nov 20, 2011
  • 4 Answers
SOURCE: gasket repair
I've used a toothpik wooden or like the dentist uses and clear form-a-gasket silicone and put that in place of the gasket. and assemble the watch.wipe off any excessive silicone (be care not to have any or as little excess as possible)and allow to dry and then make sure your watch operates correctly.
Posted on Oct 21, 2013
toddtrb
  • 100 Answers
SOURCE: How to replace wristband on a casio 2894
Cmo Cambiar la Correa Reloj Casio How to replace the Casio watch band... This should help you
Posted on Sep 07, 2015
My casio pro trek 2894 is frozen it shows op en ontop and when i press the setting button it resets time to 12h00
Hi
Have you checked that all buttons when pressed come in and out easily?
Sometimes the little spindles that press the contacts inside the watch do not come out completely and remain "pressed" even if the button appears to be "out"
Clean the watch, with particular attention to the buttons area so they can move easily in and out. If this does not do the trick, open the watch with great care not to damage the threads on the plastic case and visiually inspect if the buttons travel easily in and out and that all springs if fitted are sound. Remove and replace the batteries with new ones (DO NOT use bargain batteries from that "auction site")
and reset the watch.Try again, if ok carefully clean the back seal apply a little vaseline to the top of the seal and close the case. DO NOT over tighten the screws as this will damage the plastic thread and the watch will not seal properly and will be likely to flood with moisture. Good luck
Jan 25, 2017 | Casio Watches
Could you send me the manual for my Casio Sports aw80d-7av. I am unable to download it to my computer
We don't send anything by post. This is your manual here. I have just downloaded it. some of the sites advertising it are scam sites, but this one is Casio legit.
http://support.casio.com/storage/en/manual/pdf/EN/009/qw2747.pdf
It is accessed from Casio using the link below
AW80D 7AV Sports Mens Womens Ladies Digital Analog Wrist Watches CASIO...
Jan 15, 2016 | Casio Mens Sport AW80D 7AV Watch
Gasket repair
Oct 21, 2013 | Casio Watches
I need the users manual for NEXXTECH G-SPORT watch, CR2025.
I've had good luck using Google for finding owner's manuals.
Sep 01, 2012 | Casio G-Shock Sports Watch
Casio G-Shock mute problem
Press the mute button and the sound will get back.
Jan 22, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
I have no sound on my casio baby g watch's alarm. The alarm flashes but there is no sound
It seems likely that the watch has been set to the "silent" mode and you should be able to turn it back on by using the "mode " button
If you haven't got instructions on how to do this, you can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
May 27, 2010 | Watches
Setting time on a casio sport watch
You can get instructions from the Casio web site.
Select "support" and the "manuals", watches;
Accept terms
Mar 15, 2010 | Watches
Casio Illuminator w-94h
Hold down the "Adjust" button (top left) for three seconds. It won't adjust unless you hold the button down.
Press "Mode" (bottom left) to change what you're adjusting, seconds, hour, minute.
Press the top right and bottom right buttons to adjust the number up and down.
Press "Adjust" again when you're done setting the watch.
To change date, alarm, alternate time, etc, press "Mode" to get to those functions before hitting "Adjust."
I hope that helps.
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
Watches Logo
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
