Medical Logo
A
Anonymous Posted on Mar 27, 2019
Hi all I have an electrocardiograph contec 300EG with the following fault: when turning on the computer it presents the usual load screen, but when it reaches 100% it goes to black but only the scree
The equipment continues on and you can even hear the beep of the keys ... Has this error occurred to someone? How did you manage to solve it?
Mathew
Level 2:
Sergeant:
  • Expert 182 Answers
  • Posted on Mar 27, 2019
Mathew
Expert
Level 2:
Sergeant:
Answers
182
Questions
0
Helped
55856
Points
622
Ok, so it's posting which means that the startup systems are working but the OS isn't taking the hand-off. Check for a tiny reset button on the back and if it's there try pressing it for a few seconds to see if that helps.
Now having said that, since it is a medical device, I strongly recommend contacting the customer service line of the company that makes it if the reset isn't an option.
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on May 25, 2008
SOURCE: wont turn on, bios beep code
Seems heat-related motherboard POST failure. Replace it.
Anonymous
  • 196 Answers
  • Posted on Oct 08, 2008
SOURCE: computer monitor goes blank after initial start-up reaches the desktop
Try setting your graphics card output to something simpler like a basic 640x480 resolution 64k colours and see if it still does it... it maybe that you have the resolution/colour depth to high for the monitor to properly handle
if it is stable at the lower setting slowly increase untill you reach a point that you and your monitor are both happy
jomabug76
Josh Whitehead
  • 1148 Answers
  • Posted on May 17, 2009
SOURCE: Beeps half-dozen times then shuts down.
try ur windows disk,,put it in and go from there,,reformat if u have to,,or try sytem restore,,
Anonymous
  • Posted on Nov 11, 2009
SOURCE: Gateway Model # GP6-450,when turn the computer on
BLACK SCREEN WHEN START . STAY BLACK
Anonymous
  • 15935 Answers
  • Posted on Oct 01, 2010
SOURCE: Frigidaire gas range error message....F1
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
#$%Tf
Please my contec ECG 1200 is working perfectly only later it started showing me ECG timeout and can't print
The Contect site does not offer document downloads for this machine but there is a contact page. The company headquarters is in Japan with subsidiaries in China and India (manufacturing, I suspect).
ECG1200G Electrocardiograph
http://www.mp-medipro.com/pdf/EKG%20CONTEC/1200G.pdf
There are U. S. based distributors who offer the device and technical services.
Here is a video on how to load paper into an alternative ecg machine. Perhaps the process is similar. I suspect calling the provider of the machine you have is an option to try.
EDAN ECG How to load thermal paper
How to load paper
How to load paper - Fixya
www.fixya.com > Forum > EKG/ECG Machines
39 mins ago - How to load paper - EKG/ECG Machines question. ... Machines. Open Question ... Aug 30, 2012 ' Schiller Cardiovit At 2 Light Ecg Machine.
Loading paper into the MAC 1200 ecg machine - Fixya
www.fixya.com/.../t4590309-loading_paper_into_mac_1200_ecg_mach...
Apr 19, 2010 - loading paper into the MAC 1200 ecg machine how to load the paperinto the machine? ... Ge Medical Systems Ge Marquette Mac 1200 question.
Contec ECG Monitor & pulse oximeter Ekg printed sheet ...
www.hcuck.com/search/p1207318-contec_ecg.../ekg_printed_sheet
Question about Ge Medical Systems EKG/ECG Machines ... Open the . ... ...ekg-manual The paper is is backwards, there are 4 ways to load paper BUT only 1 ...
Electrocardiograph (EKG / ECG) Questions and Answers
Dec 21, 2015 • Medical
Everytime that i do an EKG it states drop ,I replaced the of clips and it still says drop,what can I do to correct this problem
Either one of these is causing the problem:
Battery is dying, or
malfunction.
replace the battery to see if it works, if not, replace it.
Always read no paper
it could be the size of the paper that is selected in the print properties, or the sensor is failing in which case you will need to take it back to manufacture.
Hi how do i restore an emachines tower to factory settings, and do i need the disc as i dont have it
Press F11 after you turn the computer on and before windows begins to load. If you have a working recovery partition it should present you with the recovery options. Follow on screen instructions.
2answers
When I boot my acer aspire one, all I see is the windows xp logo as if it is trying to load but this just stays on and the system does not load, can you help please
Try and boot into safe mode. Turn off the computer first.
When the computer starts to load you should see the Dell splash screen first before the XP screen. When you see the Dell screen repeatedly tap the F8 key until you are presented a menu. From that menu you should select Safemode with networking. You will be followed with which operating system to run (XP in your case) then you will see all the drivers scrolling up the screen as they are loaded and if all goes well you should come up to your desktop. A popup window will ask you if you want to continue in safemode and YES is what you select.
From there you should be able to get to system restore to fix the startup issue.
If you are unable to get into the safemode please let me know so we can figure out your dilemma
5helpful
I have a Dell Inspiron/E1505. when i turn on my computer i can barely see my screen and it says Presentation Mode is turned off. how do i turn it on?
To turn presentation mode on follow this:
  1. Open Dell Quick Set
  2. Click on Display Settings
  3. Check the box that says Activate Presentation Mode
But I don't think that will make your screen brighter, if its still dark then look for the function hot key to turn up the brightness on your screen. Its usually something like - hold the "fn" key and press the up arrow several times.
2helpful
2answers
Laptop screen
Try turning the brightness up. You can usually do this by holding down the blue "Fn" key, and then hitting the key (usually the F8 or 8 key) with the blue "brighter sun" on it.
Top Medical Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Medical Expert? Answer questions, earn points and help others
