SOURCE: Whirlpool ED5VHGXML10 Side by Side Door shelves cracked
HI thanks for your question. its the door liner, that's broken, if you can repair with some epoxy puddy, only problem with epoxy puddy , it smells. so the door liner is to be replaced. thanks the appliance doc. please rate my answer. thanks.
SOURCE: lg ICEBEAM GRS512GC. Freezer cooling but fridge
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
SOURCE: I have a GE Profile
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
SOURCE: LG Fridge Icebeam Door Cooling
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
SOURCE: LG icebeam door cooling
bon jours;
SVP j'ai un probleme , mon LG réfrigérateur a porte ice beam ne. fonctionne pas correctement.Aider moi a trouvé une solution
merci
