Question about Casio Watches
My casio 3043 shows open, no buttton working, time is shown however, battery loaded full.
2 Suggested Answers
SOURCE:
grumpytoolgu
  • 69 Answers
SOURCE: I am trying to just the temperature on a Casio
http://support.casio.com/manual.php?rgn=1&cid=002
After accepting the terms and conditions you will have access to the manual which should help you solve your problem.
Posted on Dec 15, 2011
How to set time casio paw 1100 1v
On pages 2 and 3 of the manual (module 3043) you can find the instructions for automatic and manual time setting.
The manual can be downloaded here (direct download link):
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3043.pdf
Jun 24, 2014 | Casio PATHFINDER ATOMIC SOLAR WATCH...
I am trying to just the temperature on a Casio watch model number 3043
Dec 15, 2011 | Casio Watches
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
Casio PRO TREK error 'OP EN' Display frozen with the above msg. None of the buttons - except the light - works. Whats wrong .. battery charge shows FULL
The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
Mar 22, 2010 | Casio Watches
After changing the battery nothing can be changed, no function possible and"open" remains written on the display, the type of the battery is clt 1616
The battery is CTL 1616 and I had the same occurance when I opened up my model Casio model 3043. I needed to use the battery to test my model 2767 and find out if a new battery would bring it back to life (yes, it still lives). After replacing the battey back into my 3043, I jumped the (ac) to (-) and at first the watch would indicate all was well but then it would revert back to "open". I tried over and over to try and get the "open" display to clear but I was not successful. I then thought to go ahead and replace the back on the case to see if the three contact springs would change the display and sure enough, "open" no longer was in the display. The watch works perfectly as before. As for the 2767, as soon as I jumped the (ac) to (-) the "open" display went away. There is only one spring contact to the back case on the 2767 model. Unfortunately I do have an extra spring that fell out when I opened it up and I have no clue as to where it goes. I have not found anyone who can help me on the location for the shorter spring. Any advice would be most helpful.
May 20, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio protrek watch altimeater and barometer only showing ----- lines temp and clock are fine I have comparable problems With me it is even stranger. My barometer works still more or less, as long as I...
The best would be to start with the battery check (must be full power) and full resetting of the watch.
Here is the link to user manual download page:
world.casio.com/wat/download/en/manual/ - 23k - Cached - Similar pages
If all this do not help- find your nearest watchmaker and ask for help.
Dec 21, 2008 | Casio Protrek Triple Sensor Tough Solar...
Replaced battery and it says OPEN
I know the secret that CASIO is hiding behind this thing. If your watch shows "OPEN" then you don't have to go to a CASIO retail store. You don't have to send your watch with money to CASIO or go to an Authorized CASIO Service Center. I know how. Just send me an e-mail to s.duteau@videotron.ca and believe me you'll be happy to know the "SECRET" an get rid of this annoying "OPEN" over with. You want this fix! Than don't wait.
Oct 27, 2008 | Timex T46821 Wrist Watch
Like anon129 I had the same problem. Those "outdoor" functions need more battery power than just telling the time and the stopwatch do. When the rechargeable lithium battery gets old and tired - which they apparently sometimes do for no very good reason - it can't provide enough power when required to, so it goes into recovery mode. It's very annoying but if your battery level indicator is already showing H the only solution is to replace the battery.
My second battery seems to be lasting better, but I'm not leaving it charging in the sun for ages this time, as I think it overheats it when the battery is full. I'm also not using the outdoor features as much, and the light hardly at all.
Apr 13, 2007 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio GW-1200BA G-Shock
Try taping it to the inside of your window for a couple days and see if that makes it charge up enough to act right. You might also want to make sure that you don't have the "auto light" on. If the light turns on when you tilt the watch to a 45 degree angle then press the light button for 2 seconds to shut that off. If that doesn't work for you then you are probably going to have to have the battery changed.
Dec 31, 2006 | Casio G-Shock GW1200BA-1AV Wrist Watch
Watches Logo
60 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
