On the disk management dialog box, the name is there but on my pc view it reads local disk
Well know issue. Check here for details: https://answers.microsoft.com/en-us/windows/forum/windows_7-files/explorer-changes-volume-label-to-local-disk-will/2ef5dc42-f370-e011-8dfc-68b599b31bf5
Testimonial: "Thanks but it was just fine in the explorer untill it changed all of a sudden I thought there's an issue with the drive at first. Anyway i'll get used to it"
SOURCE: Partition error
Try using the command FDISK /mbr. This should fix the master boot record. If not, then if you don't care about the data on your drive, you could wipe it clean with any of the several utilities available on the web and then try partitioning it. Search for "Wipe Disk" in Google.
SOURCE: HP Pavilion dv4-1135ee ,BIG PROBLEM PLZ SOS
the reason why this happen is that by mistake u have damage the MBR of the new partion u have created. the only way to fix the system is to format the entire system (entire harddrive) using DM thats the only way to fix it.
SOURCE: HP Laptop Recovery Parition "Not Found" error!
To resize a partition with Windows Vista, follow these steps:
Be sure to back up any valuable information, because there is a
slight chance that data can be lost when dealing with partitions.
1) Click on the Start menu
2) Right click on Computer and click on Manage
3) You may get a User Account Control dialog here; just click Continue
4) In the left pane, open up the Storage category and click on Disk Management
5) Here, you will find your partitions for your disks. Right click on the partition you’d like to modify.
6) Click on Extend Volume or Shrink Volume to extend or shrink the selected partition.
SOURCE: Systemax factory restore - how?
Tap F4 repeatedly to launch the recovery console on SystemMax Machines with the recovery partition still intact. Then you should be able to restore the machine to factory defaults without a CD.
SOURCE: Windows doesn't recognize recovery partition after os reinstall
The issue you are having involves using multiple systems,...If your emachine came with vistan and you installed xp, you voided your warranty status...However remove your dual boot and stick to vista if you wanna keep your restore partition working properly.....On a side note theres usually conflict with running OEM OS's on dual boot...typically it doesnt work and if it does it doesnt work like you want it to! so here is what you can do..Call Emachine up and fib to them a bit (just alittle) tell them that you cought a nasty bug and it messed with your restore partition and now you cant restore your pc....request the factory programing discs (if you ask nicely they'll hook you up 99.99% of the time) you get the discs so you can reprogram the pc to factory spec if you ever wanted to. Now use a retail version of vista and a retail version of xp. and create your dual boot, feel free to remove your restore partition if you want (cause you have the factory programing discs if you wanna go back to stock stuff YAY) I hope this helps!
Testimonial: "Highly knowledgeable and an awesome guy for taking his time to share his expertise with the pc community. Thanks again!!!"
