Question about Janome Sewing Machines
My janome sew precise sew machine lcd screen is going very dim, can I fix this thanks
  • Janome Master
  • 1,188 Answers
Likely you will find it has an elastomeric connector between the LCD and its circuit board that has failed. If you have experience with this type of connector it can be replaced IF a suitable connector can be found. So not likely a DIY repair.
Posted on Mar 30, 2019
SOURCE:
mallow1
  • 35 Answers
SOURCE: lost manual to Hello Kitty sewing machine made by Janome
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link tothem:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Posted on Aug 16, 2008
bargainbox
  • 1388 Answers
SOURCE: janome e1 error
The erreor message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
www.bargainbox.com.au
Posted on Nov 21, 2008
lavon82931
  • 17 Answers
SOURCE: owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Posted on Jan 25, 2009
SOURCE: Download a Janome (Jem 639) sewing machine manual
Just today  i got out my little janome i bought years ago and it is this model.  There was no "manual" with the machine.  All that came with it is a large 20X14 two sided print out.  I can scan and send this to you with an email address.
Posted on Mar 02, 2009
bargainbox
  • 1388 Answers
SOURCE: Janome Memory Craft 5700 LCD Screen
The LCD Backlight is prone to going dark eventually and fails progressively, but you can buy a replacement and even instal it yourself.....
We can now supply the LCD Backlight Screen for the Janome Memory Craft MC 8000 and Memory Craft MC 5700.
Keep your old Janome, save money and reduce unnecessary landfill.
It also comes with comprehensive installation instructions from the Original Janome Service Manual which are sent in advance so you can look at the "How to do it" before you decide whether you wish to DIY or enlist the services of a trusted friend or take the LCD Screen and installation instructions to your friendly local technician and have them do it for you.
Here is the LCD Backlight Link
Posted on May 31, 2009
My janome 300e screen has gone dull after not using it for awhile.How do I fix it.
A screen that is dim is a problem that for most is not a home repair solution. Basically, a computer component is failing.
How to Repair Faint LCD Display Module
Dec 16, 2017 | Janome Sewing Machines
Touch screen for MC9000
the motherboard could be going out the machine would need to be checked
Mar 15, 2012 | Janome Memory Craft 9000 Computerized...
The LCD screen on my janome 9000 sewing machine has gone blank, but i can still sew it's just i can't see the screen, can it be fixed?
Either the bulb has burned out or you have accidentally turned the control to darken the screen. Look in the top where the feet are stored. You should see a half moon shaped valve on the inside edge of the top front - that is the control for the brightness/darkness control of the screen.
Nov 28, 2010 | Janome Memory Craft 9000 Computerized...
I want to sell my 1991 New Home memory Craft 8000 sewing machine
A good place to see what machines are selling for is Ebay. That's where I sold a sewing machine and an embroidery machine.
It helps to know your product and machine embroidery lingo.
What are cassettes? Floppy disks? These make the machine borderline obsolete.
Memory cards are still around, but most EM now have USB connectivity or USB flash drives.
Satin thread? Embroidery machines use Rayon or Polyester embroidery thread.
Having had the machine recently serviced is also a plus.
Mar 19, 2010 | Janome Memory Craft 9000 Computerized...
The sewing advisor screen on a Janome 8000 is getting dim.
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Jan 26, 2009 | Janome Memory Craft 9000 Computerized...
Display screen has gone out on Janome 8000 machine.
The part is an LCD screen that needs to be rebuilt by the Janome Company. You will need to take the machine to a Janome dealer for this repair because Janome only sells to it's Dealers.. Plan on spending more than $300.
sewman7
Dec 11, 2008 | Janome 8080 Computerized Sewing Machine
Janome memory craft 8000
The screen is going bad and needs to be replaced. Unfortunately, it is obsolete.It is my understanding that a Janome Dealer can take your screen and send it to Janome to be rebuilt. It will take about a month. Be prepared to spend more than $200. The sewing light is the same one that is used in many Janome machines I.e. MC9000 and should be available from almost any competent sewing repair shop.
sewman7
Oct 28, 2008 | Sewing Machines
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
