IT DONT NAIL
SOURCE: Leak inside Bostitch N80 Nailer, won't drive nails
If the unit is leaking it most likley need a rebuild kit. Go to a Bostitch service center and ask for an ORK-11 kit. That is all the o-rings needed to do an over haul. Or just have them do it.
SOURCE: Stanley Bostitch Coil Framing nailer blows head off of nail?
Make sure that when you run with one gun that your psi is between 90-110. You may need a kit. Is it an RN45 or 46? Go to Stanley Bostitch online and look up parts and schematics. Kits should only be about 15-20 dollars, easy to put in, and come with instructions. Lemme know. Please rate me
SOURCE: I need an exhaust valve for a Bostitch N80 Framing
i check with my bostitch suppler that came back as N/A sorrey
SOURCE: My Bostitch N80 fires full auto when I hook it
I would check the safety first to make sure not stuck because this tool is a bump fire. Let me know and then I will find a kit and schematic for you or you can go to Bostitch.com and find the parts online, but I honestly think that you have a safety issue or the trigger valve is malfunctioning.
Testimonial: "Good advice. A starting point with next steps if it wasn't the first thought. "
SOURCE: How do you adjust nail depth on Bostitch N80
i think this model has no adjustment. if it does it is on safety tip. if not you can only adjust air pressure.
