Miscellaneous Logo
R
Reta Nysucj Posted on Mar 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2003 Cadillac cts. while the car is running, the battery shows discharging and when it's not running, the amps build back up
Pcm2048
Level 3:
  • Master 754 Answers
  • Posted on Mar 26, 2019
Pcm2048
Master
Level 3:
Answers
754
Questions
0
Helped
200956
Points
2186
My guess is that you are not measuring something correctly. It is not possible to charge the battery while the car is not running, unless you have a battery charger connected.
5 Related Answers
Anonymous
  • 5158 Answers
  • Posted on Feb 01, 2009
SOURCE: T/C light comes on in the dash of my 03 Cadillac CTS
T/C would be traction control i would think
Robert
Anonymous
  • 54 Answers
  • Posted on Feb 04, 2009
SOURCE: Burning rubber smell inside car-2003 CTS Cadillac
Diagnosing this will be subject to a process of elimination. It could be the radio, blower motor or any other accessory particularly ones with moving parts; Try switching those off and try to note when this problem occurs and what is on/whatyou are doing. Something is getting hot causing the smell so it will be a situation where the accessory will have to run a while before doing it. It is a possibility that there is an electical curcuit overheating, but less likely. Lets rule out accessories first and give us an update. GL
Anonymous
  • Posted on May 17, 2009
SOURCE: 2003 cadillac cts - car dies while driving
hi it sounds like the acclerrator pump on carby when you first take off is this whot it dose .
Anonymous
  • Posted on Sep 18, 2009
SOURCE: CD Mechanical Error on 2003 Cadillac CTS
take the radio apart and take them out one by one, i just fixed my yesterday
john h
  • 29494 Answers
  • Posted on Dec 14, 2009
SOURCE: 2003 cadillac cts v6 3.2 liter. white smoke
u have a leak in the heater core the oily smell and mist is anti freeze sounds like a small leak because usually u would have a wet floor if it was large -two choices check and repair as necessary the core or can use an additive with a stop leak they usually work well on small leaks
My 2003 Cadillac CTS starts then immediately dies. Causes please.
Question edited for clarity.
Question moved to model category.
By disconnecting the battery, you also disconnected all the set up of the security and engine immobilizer coding.
https://www.google.com/search?q=2003+cadillac+cts+security+system+reset
How do i perform the 2003 Cadillac CTS anti theft reset?
Vehicle History https://www.vehiclehistory.com > questions > how-do-...
To reset the anti-theft system in your 2003 cadillac cts depress the key fob's panic button for five seconds before pressing the lock button twice standing ...
2 answers · Top answer: To reset the alarm on the 2003 Cadillac CTS You have two options. You can pop the hood and disconnect the positive battery cable, then leave it off for ... People also ask
How do I get my Cadillac out of anti-theft mode?"
Look for a button that allows you to slide the physical key out of the fob. Step 2: Turn the vehicle key to unlock the car door without releasing it. Hold the key for 30 seconds in this position. This will signal to your car's system that you have the right key, and will enable you to bypass your car's alarm system.
Should the engine be running when adding coolant to my 2003 cadillac cts
If you just drained it & are refilling,then yes,the engine
should run & warm up until the thermostat opens & you
keep adding.
If it isn't hot & circulating thru the entire system, you won't
get it close to full with the rad cap off
2003 cadillac cts will not eject cd
Hi, Worst thing you done was to remove the battery, but ref: CD player look under the volume control (on/off) you should find a very small hole enough for a paper clip to be pushed in & eject the cd check your fuse since removing battery may have caused quick short touched & blown fuse. Please give feedback at [email protected] Thanks, Malcolm Campbell.
2003 Cadillac cts service engine light & traction control light don't work. I just purchased this car yesterday and noticed that both the MIL and the traction control lights are not working. The...
Unfortunately, is either a faulty ECM or with the ECM wiring. Check the connectors at the ECM with the negative battery cable disconnected. Are there any other DTCs?
How to reset the airbag ligt for 2003 cadillac cts
Reset airbag? I doubt there even turned on
Any light you get on your dash is
a System Malfunction ,that you have
to check for codes,diagnose & repair
If you clear the light,how would you have it repaired?
Surely you know the proceedure
We have had OBD1 & OBD2 Vehicle On Board
Systems, going back 30 years now.
8helpful
2helpful
2answers
The AM/FM radio in my 2003 cadillac CTS faded to only static
check antenna cable connections at radio & antenna.suspect power antenna if equipped.
2answers
Ampage needed for a 2003 Cadillac Cts
There should be a sticker on the old battery, either on top or on the side showing the cranking amps, and the cold cranking amps.
( if you still have the old battery).
2answers
2003 Cadillac cts battery up/won't start
it sounds like to me the battery is dead. a way to test that is to trun the headlights on and see if the headlights dim if they do it has a weak charge
Top Miscellaneous Experts
H Smith
Level 1 Expert
Robert
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
