Question about Lands Phones
Phone does not flash when messages are left
I changed telcos and have a message service but the phone does not give me any indication when a message has been left it used to flash but does not now
    Top Expert:
  • Lands Phones Master
  • 64,266 Answers
Sadly I know of no answer but you need to ask it of the phone manufacturer .
Posted on Mar 28, 2019
SOURCE:
SOURCE: GE 28112 phone voicemail indicator wont turn off
I also had this problem. I have my phone thru Charter. It seems that you may need to call your telephone support (Comcast or whoever) and set up your service for voicemail. You may need to make up a pin number for this. I called Charter telephone service and the guy walked me thru the steps I needed to get set up..
This solved the problem for me.
Posted on Oct 21, 2007
  • 18 Answers
SOURCE: panasonic kx-tg2740 cordless phone - how to change message?
  • Step 1Begin the recording process by first locating the "Change" button on your answering machine. This button initializes the answering machine for adjustments to the settings of the various features.
  • Step 2:Locate the microphone on your answering machine and lean towards it until you are about nine inches away.
  • Step 3:Locate the "Annc" button. Press and hold the "Annc" button until it beeps. Begin recording your message.
  • Step 4:Watch the message window while you are recording your message. It keeps track of how much time has elapsed since you began recording. You can record a message that is up to three minutes long.
  • Step 5:Locate the "Stop" button and press it when you have finished recording your message. The answering machine will play your message back at this point. If you are not satisfied with your message, repeat the steps to record it again.
  • Step 6:Press "Annc" if you want to listen to your message again.
i found this i hope it helps
Posted on Jan 10, 2009
  • 52 Answers
SOURCE: message Contact service Nokia 6021
It sounds like it has gone into secure mode...have you entered any codes unsuccessfully into your device before it did this? If you entered any codes in before this happend and you have turned off your phone and turned back on and it's still doing the same thing..unfortunately anything you saved to your phone is a loss cause.
Posted on Feb 11, 2009
SOURCE: CD445 voice message icon won't stop flashing
This feature is country dependent and may not
appear in some countries.
If you have subscribed to the voicemail service
from your local service provider, icon turns
on when you have a new message in your
mailbox. After you have accessed to all the new
messages, icon will turn off automatically. If
you find that the message waiting indication
cannot be turned off by the network, you can
still turn off the message waiting indication with
your phone by the following step :
In idle mode, if voice mail waiting icon is on,
long press the redial key to turn off the voice mail waiting
icon.
Once you choose to delete the message waiting
indication, all the other handsets registered to
the same base station will turn off the message
waiting indication accordingly.
Posted on Aug 30, 2009
miladcpu
  • 65 Answers
SOURCE: Samsung (GT-C3200) my message service
*2767*3855# in home screen
Posted on Aug 08, 2011
Please may I speak to real person
your message service is provided by your mobile phone network provider. As you did not provide this information I suggest searching at www.google.com for the mobile phone providers web site and go to this and look for FAQ's or support or help .There will either be a phone number or a live chat help .
What normally happens is when a message is left the message service sends a MWI (message waiting indication) via SMS to tell you to access Message bank. The SMS usually under messages then gives you the phone number to call to access your recorded messages. eg TELSTRA uses 101 optus uses 123 vodaphone uses 121 they are all different depending on provider .
Aug 15, 2016 | Cell Phones
Tried holding down the OFF button until it sounds that it has fixed the blinking light...it works but afterwards it starts blinking again,,,,still no message....can you help???
Do you have telco-provided message-center? Their message-waiting indication on the line (reversed polarity, I believe) can turn on the message light on some phones. They usually also provide a "stuttered" dial tone when you first go off-hook.
You'd need to empty that mailbox to get rid of the indication.
Sep 30, 2014 | Panasonic Kx-tg9341t Cordless Phone Dock...
How to check voicemail messages
I assume you mean voicemail messages taken by voicemail service on your telephone line, the ones indicated by a flashing "voicemail" indicator on the phone. You may need to contact your service provider as not all systems are the same, but here's how it usually works. From your home phone, dial your own number so that the voicemail answers. Press the "*" button and you'll be prompted to enter your passcode. (The default passcode is usually the last 4 digits of your phone number, and you enter a new one when you go through mailbox setup.) Once you've entered the passcode and are in the voicemail system, voice prompts guide you through how to access messages and make setup changes. To process is usually the same to check your messages when you're away, although some service providers may give you a different access number to call. Again, check with your service provider for all the details if your system is different.
Sep 14, 2011 | Vtech 5.8GHz Analog Cordless Phone
How to turn on mwi on t7316e i have call waiting with my on my phone through my phone service get a fast busy when we have a message but the light doesn't  flash.how do i activate the MWI on a nortel...
The stuttered dialtone that your getting to indicate that you have a message is provided from your telco provider.The message waiting light on the system is used by either the internal voicemail with the system or by the receptionist.The message waiting light will not work with telco provided voicemail.
Apr 10, 2010 | Lands Phones
All phones are flashing red
This is a "Voice Message Waiting Indicator" and it means that you have a new voice mail from your telephone service provider, or a new message on your answering machine. A lot of people do not even realize they have voice mail from their service provider because all the phone companies bundle services now. If you do not have a message on either you can reset the indicator by following the instructions in the manual
Jun 30, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
icon.
Jun 01, 2009 | Philips CD4451B/37 Phone
How do I turn off message waiting indicator light
The VMWI led will stay lit if you have voice mail service from your telephone service provider. A lot of providers will also give a broken or stutter dial tone when you first go off hook as an indication of messages waiting. If you hear a stutter dial tone when you first go off hook, you will need to contact your telephone service provider. If not, you can try a simple reset on the base unit, just unplug it from teh AC adapter for about 5 minutes and then plug it back in.
Mar 17, 2009 | Uniden 5.8GHz Dual Cordless Phone
Nortel Venture Display:Can't delete message ''feature ON Line 1''
Try reversing the polarity of the phone line - some Central Office equipment reverses the line voltage to indicate Message Waiting. Your jack may be miswired (for a lot of phone equipment, polarity doesn't mattter).
Jun 30, 2017 | Nortel Lands Phones
Erase messages
Have you tried the telco message waiting clear?
Options, 10, *, Line Key
Try for each line key and see if that helps.
Jul 30, 2008 | Aastra Telecom Aastra Venture Corded Phone
Voice mail indicator light is always on
I recently changed my number and when I did, I received the same problem. It appears that AT&T didn't add the Message Indicator Light service to my new number. Once they did, the message light works!
Try calling your phone service provider and asking if they have a Message Indicator Light function.
Apr 28, 2008 | RCA 25414RE3 Corded Phone
Lands Phones Logo
43 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
