3 Causes for printing Blue Lines on the side of the pages.
01. If it happens with test pages from the machine itself as well as docs;then most likely it is a bad cyan cartridge.if you open the drum shutter on the cyan cartridge,can you see a line on the drum?
02. If the Drum is opened and you can see a continuous line of blue toner is at both sides of the drum. Chance of getting blue lines printed on the side of the pages.
03. If the cartridge is leaking then and will need to be changed.thats why it's ending up on the belt also and it prints blue line on the side of the pages.
SOURCE: HP LaserJet HP 2840 printing fades away on one side of page
The carousel has slipped out of alignment. Force it back with a flat blade screwdriver.
SOURCE: HP 2840 will not print on 3 inches of left side of page
Take the toner cartridge out, shake it back and forth, and turn it around in a circle a few time. Put it back in the priter, and print. Order a new toner cartridge.
If this is an inkjet printer, ignore this response.
SOURCE: 2840 only prints on right side
If you are a bit adventurous and a bit patient, you perhaps can fix this yourself, and not require any disassembling. It worked for me on a similar 'carousel' unit... hp2550L.
For extra info, check this post out. http://www . fixyourownprinter . com/forums/laser/40284 (remove spaces)
If you look closely at the spot where a toner cartridge slips into a slot of sorts, you might see left side aligned and right side just a little off of 'good alignment' for that slot. What I did is to pull on the top of the black-plastic gear. Pull it toward the center of the printer.
There is a small, white gear at the very top of the black gear (not easy to see at first). By this pulling and bending of the black-plastic gear, you can get the gear teeth free of the white gear --- for just a moment. Just enough for the gear teeth to free-up and find their proper place. It doesn't take much.
When done, take a breadth and relax. Turn power off/on, and try it out.
