SOURCE: How to clean the Drip Pan?
the Evaporator Tray should slide out after remove the bottom grille two clips hold it in...if you can't get it out use a wet shop vaccum with a rubber hose taped on the end ot it...let me know if you can get it.
SOURCE: How do I empty the Drip Pan
Remove the grill underneath the doors. A flashlight helps, look for a plastic pan, it should just lift out. Some of the older models the pan is bolted down. If you still cant find it, slide the refer out and take the panel off the back, some are easier this way.
SOURCE: Cannot remove drip pan
im sorry but that drip pan cannot be removed you might have to do the best you can with it in there.
SOURCE: Do I need to empty the water from my drip pan
the pan is there to catch condensation from the compressor during the refridgeration cycle. the water build up to me indicates one of two things. Either the refrigerant level is low and it is freezing up then thawing, or if you have ice or water dispencer it could have a leak in the line. the only thing other than that is a leak in the magnetic door seal or other insulation causing condensation. hope this helps
SOURCE: need replacement drip pans for ge xl44 gas stove
u can find the parts only in the service center of GE appliance center.but if ur unit is more than 10 years,im sure no parts available.
