Unfortunately, this happens a bit. See the Service Manual which will show its replacement:
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
SOURCE: KitchenAid model KB26G1XGN. The planetary gear
Hi TJEWKES67. Before you tear into the ‘guts’ of your mixer any further, I’d like you to make a simple check the vertical play of the planetary. Locate where the planetary comes out of your mixer’s head, and place your left index finger on the edge of the planetary (rest your nail edge of the mixer head). With your right hand, push the planetary straight up (like you were trying to push it through the top of your mixer) until it stops, then let go. How much vertical movement did your index finger feel as you did this? Your planetary shouldn’t rise vertically more than a 1/16 of an inch, or less. If that’s the case, relax, your planetary is not coming out of your mixer, but just normal play within the transmission, and perfectly OK.
Before linking the beater to bowl clearance with the planetary gear ‘falling’, it would be much easier to first check the adjustment screw on the back of the pedestal to ensure that is properly adjusted. You don’t say how hold your mixer is, but I assume it is out of warranty.
Do you still have your Instructions & Recipe Manual for your mixer? If not, you can easily download a PDF version of it from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case, use KB26G1XN, and select the file that appear under Owners Manuals: KB26G1XGR5.pdf (2974.69 KB) and save it to your PC. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance, which I have extracted for you below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Beater to Bowl Clearance:
Your Stand Mixer is adjusted at the factory so the flat beater just clears the bottom of the bowl. If, for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, you can correct the clearance easily.
1. Unplug Stand Mixer.
2. Place bowl lift handle in down position.
3. Attach flat beater.
4. Adjust so flat beater just clears bottom surface of bowl when in lifted position by turning screw (A) clockwise to raise the bowl and counterclockwise to lower the bowl. Just a slight turn is all that is required: the screw will not rotate more than 1⁄4 turn (90 degrees) in either direction. (The full range of adjustment is 1⁄2 turn, or 180 degrees.)
5. Place bowl lift handle in up position to check clearance.
6. Repeat steps 4 and 5 if necessary.
NOTE: When properly adjusted, the flat beater will not strike on the bottom or side of the bowl. If the flat beater or the wire whip is so close that it strikes the bottom of the bowl, coating may wear off the beater or wires on whip may wear.
See second comment...
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
SOURCE: The planetary mechanism (gear, plate, etc) on my
It appears that retaining ring (7) has snapped. It is the retaining ring which attaches to the drive shaft. Here is the parts diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
From it you can see how to remove the case cover and access the gear train. You may have to replace the shaft if its groove is worn allowing the retaining ring to slip off.
SOURCE: how do I remove planetary in order to find and
Download a copy of the KitchenAid Service Manual here:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers your model.
