SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
SOURCE: Kenmore 70 Series Dryer
The fuse probably blew due to a blockage of some sort. Check your ventpipe. It may be full of lint. The fuse is a small white part held onto the blower housing with 1 screw. It usually can be found under the dust cover on the rear of the dryer. It has 2 small wires hooked to it and it is wired in series with the door switch. When the lint gets built up and dryer over heats and fuse blows. The result is just as if you opened the door.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: kenmore dryer hums/heats up, but drum does not spin!
Depending on the type of door the dryer has, is how you approach the
access of these dryers. Mostly though you yank out the filter
first.Remove the 2 screws in the filter housing on top.Then use a putty
knife to pop the top. Remove the screws holding the front panel on.
VERY IMPORTANT! Raise the front up an inch before pulling forward or
the panel clips will break! Some models have a panel on bottom. If they
do then this panel must come off first. Then you remove the door
springs and back off the screws holding down the bottom of the door
panel. Then pop the top and remove the screws on top to get the panel
out of your way. Yank out the tub. Clean the junk out (send me the coinery) oil the wheels and Idler with temp resistant zoomoil from ace hardware. Use this guide to replace dat belt Kimosabe:
BELT CONFIG 101
SOURCE: Dryer Won't Start
Make sure it has power. Then:Check the door switch.
A little lever sticking down through top right of door opening. If it is
not there you will need new door switch(sometimes the little lever
breaks off). If it is there and does not click when you press it in you
need a new door switch. if it clicks when you close the door
then you have a bad thermal fuse.The thermal fuse is found by taking
the back of the dryer off. The fuse is an oblong white plastic piece
with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
SOURCE: I have a kenmore 70 series electric dryer. The
There is a circuit board that is in the control panel. It is mounted into a plastic carrier that is skrewed into the panel. You could pull it straight out and check it with a multimeter to see if there is continuty, check the two blue resisters and if no continuty, replace!
