SOURCE: All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
SOURCE: airbag light keeps flashing and i have no horn
your clock spring is broken... can be quite costly with labor
SOURCE: 2000 Park ave - power seat problem
The electric adjustment motor has a drive-gear that engages a gear on the shaft of the adjustment screw (90 degree engagement). The gear on the adjustment shaft looses a tooth. Adjustment motor whines, drive gear on adjustment motor spins, no action though because of missing tooth. A 12mm 1/4" drive socket on a wiggler (universal) on the end of a 6" extension can engage the not on the end of the exposed large adjustment shaft and, as the shaft is lightly loaded and the electrical switch engaged, one can get the shaft to spin almost one revolution at a time until the seat is high enough. It is hard to reach the nut necessary (inside the dull-grey clevis that the shaft threads into) and I had to take off the seat pad by removing the 4@ 13mm nuts (and 3 @10mm nuts holding the center section with the driver's cushion) to more-or-less easily access the situation. Dealership wanted well over $1000. to fix it. Three out of my 4 up and down adjustment motors are running, but don't adjust. PS, on my 2001 Park Avenue on each seat there is one adjustment motor for the front edge up and down, one adjustment motor for the rear edge up and down, one adjustment motor for the seat fore and aft, and one adjustment motor for the sear back tilt. Lots of complication, not so much on durability. We do not swap out drivers and adjust the seats excessively. Weak design on the one internal gear. Manually adjust it, unplug the electric to the motor, Drive happy again.
SOURCE: chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is.
Visit this site to locate the type on controller on your power chair and
you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer
for service. If your insurance purchased they power chair for you, they
may also cover the cost of repairs.
SOURCE: Chair is charged up. When we turn it on the
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
