SOURCE: Hi. We've got a CoolTech 34788. Whenever the
It's sound like normal. However when thes message come again you just press Stop/No key to terminates this function. Press Recover & see if the machine is going to recovery after self clearing. If it is then you can continue to work. Hope this will help you best of luck!
SOURCE: We have a cooltech 34700Z.
1# CHECK CHARGE SOLENOID, IT MAY NEED TO REPLACE.
2# OPEN FRONT DOWN COVER AND CHECK "LIQUID" HOSE QUICK CONNECTOR ON ISV TANK
SOURCE: robinair cooltech 34788 scale error reset
You may overfill the ISV tank. #1 Open front cover & close LIQUID valve on the ISV. #2 Disconnect LIQUID hose from tank,then open tank liquid valve (which you close earlier) to reduce some refrigerant manually from the ISV tank. #3 after reduce refrigerant from tank, re-connect everything & switch on the machine. #4 If you still have the same problem then you have to re-calibrate the scal. I hope this will help you
