Is the bobbin winder engaged?
Check EVERY segment of cord from the wall AC outlet to your machine.
Are there any power strips?
Are they turned ON?
Are any power strips overloaded with either too many things plugged into them, or a large power draining appliance?
I am certain you have already checked to make certain that
1) it is plugged in
2) There is not a fuse blown
SOURCE: how to identify a bernina sewing machine
Older machines, the model number is found on the throat of the machine and sometimes stamped on the cover over the motor. You can also give me the serial number stamped on the machine and I can look it up for you. I am a certified Bernina/Brother dealer and technician.
Perhaps look at Ebay, you may get lucky before your eyes become crossed looking at the many many Bernina models out there.
SOURCE: Bernina 910 sewing machine extension table
Hi Phoebe,
What you have is the extension table for the 830 and the 830E Bernina models. What you need is part number 301 276 100. This table looks a little different as it has a small see-through window in the bobbin area and also, it has no clamp (it has push-in pins). Ebay or a site like SewItsForSale is your best bet. I doubt the dealer could get one but if they could, it'd be likely around $100.
SOURCE: i need a bernina sewing machine manual
Sewing Educational Warehouse provided a very similar manual. Thanks for trying
SOURCE: Bernina 1090 only sewing backwards
1.Turn the bobbin winder off.
2.You have to reverse the wires on the carbon brushes.
3.Make sure that you have the needle in correctly- with the flat side to the back. Those machines rarely go out of time.
