Exercise & Fitness Logo
I need a manual for stex 8020t treadmill - NRS Stex 8020T Treadmill
1 Related Answer
mccluskey1
NOEL
  • 8606 Answers
  • Posted on Dec 09, 2016
SOURCE: My stex commercial treadmill speed is locked. how to unlocked it. how to increase the treadmill speed
see if any links on here helps you out.... treadmill speed is locked Google Search
Testimonial: "tried"
What is error code 11 in a stex 8020t
This might be in part due to age of machine (undisclosed) and tension on the belt you run/walk on maybe too loose as these like many items of same material under tension stretch and it is probably a failsafe mechanism to prevent personal injury. Unplug unit and remove covers (Warning! You may be exposed to electrical shock opening the unit/voiding warranty of the treadmill. There should be a tensioning unit that is adjustable and correcting tension may help solve this issue. This may take awhile after the repair to clear from the system to allow the unit to function properly again.
Servis manual
the service manual will be difficult tha you reach by free, However you can go to www. treadmilldoctor.com or www. treadmillrepairparts.com
and try it.
Merry Christmas
1helpful
Unfortunately no manual is available online but if you contact http://www. synergyfitness. com.au/ they should be able to help you
Stex treadmill about error 2
adjust the Speed sensor, see the diagram, clean it, test for open or faulty, and tight the connector very well.
Lube the deck belt, see the video, lube the rollers bearing front+back too , test the drive belt motor and replace the belt if necessary. God bless you
However you must try to Run the software calibration after your fix it.4d80cf2e-89d9-4476-902b-88e5991886e8.gif
1helpful
In Stex X6 treadmill speed up key not operating above 1.0km/hr
Hi I am using stex x6 machine 09 speed button not working
2helpful
Error code 1
I am the same Problem with Stex 8020 T Error Code 1
Treadmill Stex 8020 when switched on immediately increases speed on board (without touching buttons) until it reaches 250km...the belt isn't moving when this is happening and pressing + or - or other...
If it reaches 250km then I suspect that the upper electronics is not functioning properly contact the distributor of Stex and If under warranty they sould cover it,but send out a servicer
Top NRS Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a NRS Exercise and Fitnes Expert? Answer questions, earn points and help others
