SOURCE: What is required to convert an LPG Rinnai 1001 to
Its complicated to convert. Get a qualified gasfitter to do it. The part number to convert LPG to Nat Gas is R1911 (at least it is here in New Zealand)
SOURCE: Rinnai inbuilt lpg gas fireplace IB35ETR wont
You don't mention any error codes displayed. If this is the case I would start with a new main PCB. It should try and light for approx. 10 seconds and then go to lockout with an error code 11 if it was a gas supply issue. This is all controlled by the PCB hence my opinion on a PCB fault.
Testimonial: "Thanks for your input. Winter is coming and I will have a look at the heater this weekend. Good, clear advice. Thanks again."
SOURCE: Is it possible to convert a rinnai avenger 25 from
Yes it Should but you will want to check with manafactuer because it will need a conversion kit for lp gas. Natural gas is a different p.s.i. than lp gas so don't try without conversion kit. It should be just a small fitting that goes inside the gas valve. Hope this helps have a good day
SOURCE: adjust natural gas to lpg
You need a new orifice - the store you bought the appliance from should have the kit. DO NOT use lp with a natural gas orifice - you will get a huge flame!
