Sewing Machines Logo
P
Pat hall Posted on Mar 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Feed dog won't feed fabric singer touch and see 756
Robert Fell
Level 2:
Scholar:
New Friend:
  • Expert 59 Answers
  • Posted on Apr 01, 2019
Robert Fell
Expert
Level 2:
Scholar:
New Friend:
Answers
59
Questions
0
Helped
15967
Points
137
On some of the singer touch an sew machines the feed dog has little rubber pads instead of metal teeth.
With age the pads come off.
A replacement feed dog can be had from SewingPartsOnLine.com for about ten dollars. http://sewingpartsonline.com/
I hope this helps, I have changed quite a few.
Bob
  • Julie Donoghue
    Julie Donoghue Oct 18, 2022
    Can you tell me where the feed dog lever is on the singer touch and sew model 756 is?
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
  • Posted on Nov 24, 2008
SOURCE: feed dog wont feed the fabric
Remove the needleplate and clean between the teeth of the feeddogs.
Ensure the feeddogs are not lowered for free motion sewing.
Don't know the make/model to be any more specific, so post back here or to the Contact Us page at  www.bargainbox.com.au if there is more to do.
Anonymous
  • 19 Answers
  • Posted on Dec 30, 2008
SOURCE: My kenmore 385 won't feed fabric
hi there check feed dogs are up not down mary h
e
Anonymous
  • 69 Answers
  • Posted on Mar 01, 2009
SOURCE: feed dog problem.
Open the bobbin case door and there should be a lever sitting off to the right. It moves from left to right. For the feed dogs to be in the up position the lever should be to the left.
sewtexas
  • 136 Answers
  • Posted on Jun 18, 2009
SOURCE: Feed dogs up but fabric won't move
where is length set?
Anonymous
  • 32 Answers
  • Posted on Aug 17, 2009
SOURCE: singer 2010 wont feed fabric
Are you sure the feed dog is in the up position
Singer sewing machine model 1425 feeder foot wont advance fabric
Not knowing this exact model or your history with this specific machine, I'll just toss out the following info.
If feeder dogs are not stepping, none of the following applies to your problem. Otherwise;
I believe the 1425 does not have dog up/down selection, therefor it uses stitch length zero (or about) to keep the feeder dogs below the needle plate when embroidery/darning.
Assuming feed dogs are stepping (rotary reciprocation), adjust stitch length toward a longer setting. Eventually this should raise the height of the feed dog step to a point above the needle plate thereby feeding the fabric.
So if choosing a longer stitch length feeds fabric, either the feed dog height needs adjusted, or something else has caused feed dogs to be lower than normal (additional repairs).
1helpful
How to drop feed dog for 5430c singer sewing machine for free arm quilting
The feed dogs do not drop on your machine. Instead, your machine uses a feed cover plate that is placed over the top of the feed dogs to protect the fabric from contact with the feed dogs. It is part #11 on page 14 of the manual
Singer 5417C Instruction Book
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
The feed on my Singer 538 will not pull my fabric thru. Help appreciated.
Without fabric in your machine and with the presser foot raised, do the feed dogs move front->back? Are the feed dogs in the raised position? Is the stitch length at a 10-12 stitch per inch setting so that the fabric actually moves (try increasing the stitch length to see if it makes a difference)?
Does your machine have a presser foot pressure adjustment? If you are sewing light weight fabric, the pressure may need to increased so there is more pressure applied by the presser foot to the feed dogs. You can also try adding a strip of tear-away or wash-away stabilizer to the underside of the fabric as you stitch so the feed dogs have something to grip.
Are the tips of the feed dogs rounded? Could be worn and need replacement.
If the feed dogs are not moving, how long has it been since the machine was cleaned and oiled?
It was working now it seems to be frozen the needle part wont move
If the feed dogs remain below the needle plate, and the feed dog lever does not activate them, then perhaps something is disconnected in the feed dog mechanism. The feed dogs should rise when stitching begins.
2answers
I have a singer touch & see sewing machine, I need to change for quilting but there are no visible switches to lower the metal times under the foot.CAN ANYONE HELP I'M ON A DEAD LINE. THANKS,
I don't know this machine but in most machines the feed dogs are normally lowered from a switch beside the bobbin case behind the door of the bobbin case.
My singer 6180 feet dogs eats fabric at the top of feed dogs fabric gets stuck and does not feed the fabric why???
It sounds like the height of your feed dogs is the problem. I don't know which model you have, but of it's a plastic casing, you will need to take it in for service.
My Singer 9420 is not advancing the fabric. The feed dogs move without fabric?
Are you sure the feed dogs have not been accidently lowered? They will still move when lowered but not feed the fabric.
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
1helpful
2answers
My fabric dosnt move foward or back wards with the petal or manually ..
if the fabric won't move then there is something wrong with the
feed dogs, check in the needle plate to see if you can see the feed
dogs. you should be able to see them & touch them with your finger
since they are not moving the fabric it would be a good idea to
have the machine checked
I'm putting a link for a free manual for the machine, you can check
in the manual to see if it show where the feed dog lever is on the
machine, if it doesn't show a lever, or the lever is not responding to
movement then the machine needs to be checked to see what's
wrong.
http://www.singerco.com/uploads/download/463_2932_esf.pdf
3helpful
2answers
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
