Question about Razor Toys
We have the ground force razor go Kart. We put new batteries in it. When I went to plug in the charger it immediately went to green. They have never been charged.
  • Razor Master
  • 26,838 Answers
Batteries generally come fully charged. They store better that way and prevent damage. It is a sealed lead acid battery and needs to be stored fully charged to avoid damage to the internal lead plates.
https://www.google.com/search?q=ground+force+razor+go+Kart&oq=ground+force+razor+go+Kart&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
https://www.batteryspecialist.ca/12v-8ah-razor-ground-force-drifter-25143400-electric-go-kart-battery
Posted on Mar 24, 2019
Testimonial: "You just made my day Andrew. You are so right. I even ordered a new charger thinking it was the charger. You are awesome! Razor web site told me it was a short. They were wrong! You were right"
  • Andrew Taylor
    Andrew Taylor Mar 24, 2019
    Neat, thanks for the feedback :>)
SOURCE:
SOURCE: Razor Ground Force Go Kart will not work.
replace thumb tab throttle. part is $12.99 from razor. go to razor site to order. i had the same problem after my daughter drove it over a bumpy sidewalk.
Posted on Mar 30, 2009
  • 3940 Answers
SOURCE: old battery not charging plug in charger green light goes out
If the system will not power on, and the LED on the AC adapter goes out when plugged into the system, then the most likely senario is the motherboard has failed. Remove the battery, Wireless card, Drives, RAM and connect the AC adapter see if anything changes. If no change, the MB is most likely bad.
Posted on May 03, 2009
  • 62 Answers
SOURCE: RAZOR v3 -- i have 2 batteries, both good, 2
try taking out the sim and blow the stuff out of it. Then put it back together and see what happens
Posted on Dec 29, 2009
  • 347 Answers
SOURCE: celebrity x scooter wont charge
Hello,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.Save as a PDF File + Print for future,hope this has helped,Colin.
Posted on Nov 27, 2011
SOURCE: packard bell netbook nav50 battery stopped charging properly. bought a new charger and battery and it still wont charge it up.
LOL, I didn't know Packard Bell was still making computers. I would think they sold you a bad battery. I've purchased new batteries before that would not charge.
Posted on Apr 05, 2012
Razor ground force go cart
I don't think this would be a problem, as long as the wheels fit the axle properly, both in diameter, and length of shaft.
Aug 24, 2014 | Razor 300001-SL Ground Force Go Kart
Tip
Gas Engine Conversion
Just converted our Razor Kart to a 49cc gas motor. Is twice as fast as the electric version but was very unstable with the stock wheels. I went with 4" slicks and is much better. Transplanted the drive train from a pocket bike with electric start and speedometer. Was a 2 day project and was well worth the time.
on Sep 12, 2009 | Razor 300001-SL Ground Force Go Kart
Repair
this unit may take several hours to charge correctly
May 21, 2013 | Razor USA Razor Ground Force Drifter Go...
Razor ground force battery says its fully charged but gokart wont turn on
Here is the owners manual for the future (in case you don't have one.)
http://www.meijer.com/assets/product_files/pdf/1000422_groundforce_manual.pdf
It sounds like the push button fuse next to your charging plug. Push that in and try again. Otherwise it could be a wiring defect.
Aug 19, 2012 | Razor 300001-SL Ground Force Go Kart
My son's ground force drifter is showing a charged battery but will not go. I see the full charge lights on the throttle but it when i depress the throttle, it does don't move. Anythought? Thanks
If the battery is gone(bad), sometimes it will show fully charged (volts are good).. but it has no amperage to "push" the voltage... It takes amperage to make the drifter move... (time for a new battery)... they don't last long...
Aug 03, 2011 | Razor USA Razor Ground Force Drifter Go...
When I turn the switch on after charge, it blinks on and off and my son can not use the gas feed on the steering wheel. The power switch blinks on and off.
hi, a blinking red light ,is telling you that a battery is going bad or you have a bad plug , or your charger is going bad .
I had a razor scooter that had the blinking red light, it was a busted plug on the scooter where it plugs in.I had one scooter that had the blinking red light, it was A battery gone bad .
good luck!
Jan 29, 2011 | Razor 300001-SL Ground Force Go Kart
The lights are on showing that it is charged but will not go. It is only 10 months old.
If the charger is left plugged in longer then 24 hours you may over charge the batteries and they will not work properly. Also You must charge the batteries once a month even if it hasn't been used.
Lift up the back end of the gocart and see if the wheels spin when you pull the throttle. If you only get a clicking sound start by replacing the control modulator. 10 months old your batteries should be still good unless you over charged them. (Leaving plugged in longer then a day) Good luck...
Nov 16, 2010 | Razor 300001-SL Ground Force Go Kart
Mar 05, 2009 | Razor 300001-SL Ground Force Go Kart
Toys Logo
41 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
