Tablets & eReaders Logo
Dennis Parmelee Posted on Mar 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset korg i3 factory settings
How do i reset it to factory
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 25, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245660
Points
21965
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
1helpful
2answers
My nabi dreamtab wont reset why?
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabi™ Sync.
How do i reset my digital2
To factory reset your tablet - Open system "Settings", then "Backup & Reset", then "Factory data reset". Once reset, all settings will be restored to factory default settings and user will be required to do the initial setting.
Reset to factory settings on Samsung galaxy 10.1
Go to applications, settings, back up and reset. If you want to save your data check the "back up my data" box, then tap the "factory data reset" and tap the "reset tablet" tab. The tablet will then be reset to the original factory settings.
How to reset factory settings
On your tablet, tap on Settings > Personal > Security. The reset to factory settings option will be near the bottom.
Reference: Lenovo Yoga Tablet 10 User Guide.
https://www.cellphones.ca/upload/manuals/lenovo-yoga-tablet-10-manual.pdf
Hope this helps!
What is a master reset
A master reset is a reset to the factory settings that was originally on your device. For instructions on resetting your iPod to factory settings, click here:
Restoring iPod to factory settings
How do i hard factory reset my apple iPad 16 GB model A1395
It's simple. You can complete this task with several steps. Just follow below steps.
You are able to reset iPhone to factory settings within your iPhone. You just need to go to "Settings > General > Reset" and then choose the categories you want to reset and then apply it. If you choose "Reset All Contents and Settings", then you will get all the files in your iPhone erased.
Once you tap on "Erase All Content and Settings", you will be asked to enter your Apple ID password. Next, you will see a Popup Message informing you that All media, data and settings will be erased from your iPhone. Click on Erase iPhone to factory reset iPhone 6 Plus.
img_2854-2ka233npl0212ndjbhnpio3z-3-0.jpg For more methods, check: How to Restore iPhone to Factory Settings
Password reset on blaupunkt tablet
How do I reset the device to factory settings?
Tap on: Settings---Back up & reset---Factory data reset, to reset the system to
factory settings.
http://www.blaupunkt.com/uploads/tx_ddfproductsbp/HW-Manual-Vollv_Android4.0.3_Endeavour_TV_seven_Engl.pdf
Reset hp slate 7 to factory settings
  1. From the Home screen, touch the All apps ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687853.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken icon, and then touch the Settings ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687854.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken icon.
  2. In the Personal section, touch Backup & reset . Figure 1: Backup & reset
    ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687855.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken
  3. Touch Factory data reset . Figure 2: Factory data reset
    ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687856.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken
  4. Touch Reset tablet .
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
