SOURCE: Fog Light Replacement Hyundai Santa Fe
The above statement is GREAT!!! The wheel-well piece folds down across the area you need to be in. There are 2 screws to undo this part. Push it back and there is a cap that unscrews which holds the wires and socket he is talking about. Unscrew the cap, unscrew the wire and housing. The bulb comes out. You pull the wire harness off and install the new bulb. It has a triangular push-in and it has to go just right so take note of how it comes out. Also, being a halogen light bulb, do not touch the bulb with your hands - the oils will make it explode.
SOURCE: ''check engine light'' illuminated, 1004 Hyundai, Santa Fe
If you live in the US, take it to qany Auto Zone store and thy will read the codes off for you, I would suspect any right thinking competitor would do the same, check if you don't have one near by.
Hope this is of some help.
Ed
SOURCE: 2002 hyundai santa fe front transmission leak
swap w/rear radiator rear doesn't require fluid.
SOURCE: where is the trans speed shaft sensor on a 2001 hyundia santa fe?
There are two speed sensors, Input sensor is located on top of the bell house. Output sensor is located on the firewall side of the bell house.
