SOURCE: 2005 honda odyssey ~ cannot remember how to reset the oil change
hold in the trip meter button on the dash before you turn on the key... keep the button pushed in, turn the key on, and wait until the light goes out( 10 sec or so)
SOURCE: Honda Ridgeline Service Manual
4WD only operates when gear selector is in L and under 18 mph. the rest of the time your 4Wd will activate automatically if the front wheels start to spin,
SOURCE: Yellow/gold wrench light 2006 Honda Accord
take it back to the servicing firm and aks them to finish the job.
SOURCE: HOW TO RESET LIGHT AFTER YOU SERVICE VEHICLE
depending on your vehicle options, turn the key to the off position and then either push the trip reset or the select/reset button and turn the key to the "on" position just before the vehicle "start" position, then wait 10 seconds and the light should go off. if not make sure the outside lights are off and set the parking brake and try again
SOURCE: How to reset the maintance minder after an oil
Hi!!
TO RESET THE MAINTENANCE REMINDER ON HONDA RIDGELINE 07-08 TRUCKS.
1. Turn ignition switch to ON (II) position.
2. Press SELECT button repeatedly until engine oil life display or service message is displayed.
3. Press the RESET button for about 10 seconds. A "MAINT RESET" message will appear. Select appropriate answer - "MAINT RESET >N" (NO) or "MAINT RESET >Y" (YES) by pressing the select button. ">N" or ">Y" is displayed on the outside temperature display.
4. Select the "MAINT RESET >Y" (YES), and press and hold RESET button again to reset engine oil life to "100".
A - 4 THUMBS - rating is appreciated for answering your FREE question. Thank you for using FixYa
