Boo some cola in it, then use a scrubby with a wood spoon the heated acid will help losen it up
Check out the advice given on the link below...
https://www.google.com/search?q=remove+burnt+sugar+from+saucepan&rlz=1C1CAFB_enGB673GB676&oq=remove+burned+sugar&aqs=chrome.2.69i57j0l5.15999j0j8&sourceid=chrome&ie=UTF-8
SOURCE: LId to 6 quart crock pot shattered
I have a 5-quart crockpot that cracked across the bottom. I've been using the crockpot liners, and they seem to work very well. No leaks, etc., and food seems to cook just as well as before the crockpot cracked. The liners sure do make cleaning up a lot easier, too!
SOURCE: Durabrand 5 qt slow cooker model MD-TC5002
My durabrand crockpot was given as a gift this past Christmas 2007. The inside part cracked severely when I was trying to make a pot roast. Where do I contact these people to get a replacement. I have not receipt as it was a gift. Walmart does not have any in stock to replace the inner part. I tried several stores. I cannot find the company online to contact them for a replacement.
SOURCE: I need a manual & cook book for the rival crock pot bbq pit
THIS IS WHERE YOU WILL FIND IT.
http://www.fenwayfaithful.com/stuph/BBQpit.pdf
SOURCE: RIVAL Crock Pot 3350 - Replacement of Cooking Pot
I need a new liner for my Rival smart pot. the crock bowl broke.
SOURCE: My Rival Crock Pot seems to cook a lot faster than
Probably, nothing. About 6 years ago the standards on these were changed, to increase low to 200 degrees instead of 180, high to 300. Things that took 6 hours can now take 4. If you are using older recipes, or recipes perfected in older pots, they will always overcook. You can check this by putting water in, covering, and checking with an instant read thermometer after 1 hour. If it is 200, there is nothing wrong with you or the pot.
Testimonial: "This makes a lot of sense. I am cooking a pot roast right now and reduced the time by a third so I'll see if that will work. Thank you."
