If you bring arms in with the brake ON it should kill the engine, From your description it's not the brake steering arm interlock killing the engine but that it stalls when arms are move forward or back? If yes, then it would imply the brakes are not releasing even though the brake lever is in OFF (disengage) position.
SOURCE: slide arm does not go completely forward
My Friend,
It seems you really have outdone yourself! The only thing I can recommend is to go to your local gunsmith ( a gun store could help in the location of one hint, hint) and have them disassemble the old gal. they will assess the damages done by your rookie mistake, and hopefully it's not too bad eh (she's a beauty she is). next time I STRONGLY recommend you take every precaution necessary to not damage you the guns or others. I STRONGLY recommend cleanings after every use, and please be sure to slide the slide arm all the way forward next time. You are lucky you were not hurt.
In my opinion though you may have broken a crucial spring, lock the slide gate shut, and/or dislocated the base of the spring. the shell not fitting I would say is a barrel issue with unburnt black powder, or a small dent in the barrel form the slide mechanism. BUT I HIGHLY recommend you do not try to repair this in your home or take my diagnosis as I have not seen the gun, nor am I a professional gunsmith.
Best Wishes,
KidKRYLON
SOURCE: 2005 Ford escape fwd & the transmission seems
It sounds like the torque converter is locking up and sticking. You have to remove the transmission to replace it.
SOURCE: passenger seat doesnt move forward or back
that motor has eithe become jammed or has gone bad. Sometimes u can replace the moor itself or you have to get a whole new seat sub-frame that has the motor assemblies on them already. getting the seat frame is the easiest repair as switching the motors can be time consumiing and difficuly if you loose a screw or washer.
SOURCE: Murray Riding Lawn Mower won't start or move
The Drive Belt keeps coming off as soon as I engage the mower I replaced the Drive Pulley and put on a new belt but it still comes off. Any Ideas.
SOURCE: No forward, only backward
Hi. If the light flashes 7 times, it has a speed controll fault. It might be the throttle lever ( wig wag ), or it might be the speed pot that controls your top speed.
Try moving the throttle lever ends up and down while you are driving the machine. Doing this wont fix it, but it will highlight the problem, if the throttle lever is faulty. Also try moving the speed pot back and forward a few times.
Good luck. Neil.
