Absolutely, Nilfisk are a great maker. If they are clean and work, they will sell locally. They are 820 Euros new!, so figure on half to a third of that.
The motor that pumps the water out of the machine is the same motor that pumps thru the spray arms. The motor runs in one direction to pump the spray bar and in the opposite direction to drain the water out. look at the cycle timer. It switches the direction. If it proves good then the motor is bad.
all wet pickup is a ball that floats when the water rises the ball floats to the top and plugs the vacuum hole shake the top if you here some thing moving thats the ball
adjust needle valve at rear of gun a little at a time , also som gums have a side fan control to adjust the width of the spray. be sure to mix the paint or material thin enough to spray ( read instructions on paint can for mixtures)
a pluged or should i say a partially pluged lower spray arm nozzle redirecting the water spray under the door causing it to spray water in a direction it shouldn't be, causing your leak. another spray arm could again have a partially pluged spray hole causing water to spray in a direction it shouldn't, or more forcefully so it blows past the door seal.. the float switch could be bad allowing an overfill, but thats usually more substantial. best of luck, ttfn
problem solved when im using access point manager to accessed my wap. the default password is "default". for unknown reason the wap seems cant be access thru http, even i enter the right password. the http page tell me that the password is wrong. But when i used access point manager from www.teletronics.com i can log in to the wap and configure it using the same password that i used on the http page.till now still dont know what's wrong with the wap. since it's working fine im not trying to find out anymore.
the default password is working too on telnet and others but it still dont work on http page and i dont see any configuration that restricted access to the wap thru http access.
