The motor that pumps the water out of the machine is the same motor that pumps thru the spray arms. The motor runs in one direction to pump the spray bar and in the opposite direction to drain the water out. look at the cycle timer. It switches the direction. If it proves good then the motor is bad.
adjust needle valve at rear of gun a little at a time , also som gums have a side fan control to adjust the width of the spray. be sure to mix the paint or material thin enough to spray ( read instructions on paint can for mixtures)
Check the spray arm. Machine water pump. After this pump pressure builds up to the spray arm. Rubber hosejunction inside the wash tub. This place gets connected to the spray arm system. You can see this when you draw the tray for loading vessels. Slowly push it and watch the junction where this gets locked into the rubber hose mouth inside the wash tub. There should not be any water pressure leak.
a pluged or should i say a partially pluged lower spray arm nozzle redirecting the water spray under the door causing it to spray water in a direction it shouldn't be, causing your leak. another spray arm could again have a partially pluged spray hole causing water to spray in a direction it shouldn't, or more forcefully so it blows past the door seal.. the float switch could be bad allowing an overfill, but thats usually more substantial. best of luck, ttfn
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
