SOURCE: vtech cordless phone appears to be mute
does anyone out there have a solution for peggy's problem? I have the same problem------Bob
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
my vt phone is lock and need to unlock it help
SOURCE: MagicJack caller ID issue
I found this solution. It worked...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190398696713
Try the "hard reboot". /1/ Unplug power from base station. /2/ Disconnect battery in each handset. /3/ Wait a few minutes. /4/ Reconnect battery. /5/ Re-plug-in power to base station. /6/ Place handset in base station, and wait a few minutes for it to recover.
You may have to reset time/date and/or the handset ##.
