Laura Prior L. Posted on Mar 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Nexxtech alarm clock and I don't know how to disable the alarm. Anyone knows how?
Terry
Level 3:
  • The Master 11,377 Answers
  • Posted on Mar 24, 2019
Terry
The Master
Level 3:
Answers
11377
Questions
Helped
4619783
Points
152765
Https://www.manualslib.com/manual/1157616/Nexxtech-8015483a.html?page=9#manual
May be a different model. If you can identify the model number it may be easier to locate an answer or manual on the internet using https://www.google.com to search.
5 Related Answers
Anonymous
  • 281 Answers
  • Posted on Mar 03, 2008
SOURCE: Timex Indiglo Clock/Radio/CD alarm clock
whats the brand and the informations about it ?
Anonymous
  • 3 Answers
  • Posted on Aug 05, 2009
SOURCE: I have lost my instruction booklet and my Next
on the top of the dock is an alarm button (clock) hold that down...will start to flash...go press the function button until u get to off...thats it!
Anonymous
  • Posted on Sep 13, 2010
SOURCE: Jensen jims 225 setting clock and alarm manually
Call Spectra at 800-777-5331, the new remote is $5.00 $3.00 Shiping
Anonymous
  • 4 Answers
  • Posted on Jan 09, 2011
SOURCE: Need setting instructions for Nexxtech
Nexxtech Instructions
1. Press Mode button to toggle between year, time, and alarm.
2. Press & hold Set button in each mode to make changes. For example: In year mode press & hold Set until year flashes then press the Adjust button to make the change. Press Set again to change month or day. Use same procedure to change time or alarm.
3. Press Mode button again to return to normal operation.
Note: You can't change the temperature, humidity, or weather trends of course because they are what they are.
Anonymous
  • Posted on Oct 30, 2011
SOURCE: don't know how to set
It's very easy to do. First, make sure the 2 little slider switches on the far right hand side that turn the alarms on and off, are in the "down" off position.
On that clock, just to the right of the large snooze button there are 5 small square buttons. Time, Fast, Slow, Alarm set 1, Alarm set 2.
Depending on which alarm you want to set, hold down that button and simultaneously push either the "fast" or "slow" button to the left of it. The numbers will move forward fast or slow depending on which button you're pressing. Keep an eye on the upper left corner to determine when you've gone past 12 noon - as the indicator for PM will light up.
Keep holding down the 2 buttons until you get to the time you want. Then immediately release the fast/slow button. Your time is set. Do the same for alarm 2 if needed. When finished, flip up the switch for the alarm you want to activate, and you're good to go. Piece of cake! It took me a few minutes to figure it out; but after doing it one time...it's easy. Hope that helps.
I love this old Sunbeam clock. Only problem is the alarm is not very loud and there's no way to raise the volume - short of connecting wires to the speaker and using a powered speaker. Cheers!
How do I preset channels on the Nexxtech AM radio Model 1219833?
The most common way to set those buttons is to tune in a station and then press and hold the button down that you want to set it to. It will beep of flash to show you that it has preset.
How to set clock radio Nexxteck Model 8007366
Contact Nexxtech on the web. Look for Support/Downloads/Manuals.
1helpful
C9 champion digital alarm
Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
May 10, 2013 • Watches
Nexxtech model 6302000 time zone change
- Press the "Mode" button to enter Alarm mode
- Press the "Adjust" button to cycle through times zones
- Press the "Mode" button again once you've selected the correct time zone
See - http://downloads.thesource.ca/630/6302000/Manuals/manual.pdf
2helpful
How to turn off alarm on GE radio Model 7-4853c
The manual says to "DISABLE THE ALARM PERMANENTLY" you should:
"Press and hold WAKE 1 or WAKE 2 until the green indicator disappears."
I did this and the light indicator to the right of the clock digital readout went out after a few seconds. I won't know until tomorrow if the alarm is permanently disabled.
Problem with launcher Pro and alarm clock. No way to turn it off or to put on snooze. I can't switch off my alarm clock or snooze. I have to turn off the phone completely to make it stop. I use...
I had the same problem the other morning. All I wanted to dowas go back to sleep, but the alarm would not shut off.
Here is how to fix it:
Go into the clock, then alarm clock and click the menu button, then settings. Go to Slide Button Behavior, which will give you threeoptions, choose none.
Now, when your alarm goes off there will be a pop up and you can either choosedismiss or snooze. Please don't forget to give thumbs up!!
30helpful
2answers
Cannot shut the alarm function off all together.
Disable the alarm permanently 1. Press CANCEL button. 2. The WAKE indicator will be flashing. 3. Press WAKE MODE button within 3 sec- onds to deactivate the alarm function per- manently.
Top The Audio Players & Recorders Experts
vince
Paul Carew
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
